Wrong bit or wrong technique ? - Router Forums
 18Likes
post #1 of 20 (permalink) Old 08-06-2015, 12:45 PM Thread Starter
gjackson52's Avatar
First Name: Gary
Default Wrong bit or wrong technique ?
I purchased the smaller box joint jig from Rockler recently. I have been making some test cuts to get this down before I try it on a project. I have been having a lot of problems with chip out. At least that is what I am calling it :-) What is happening is that each time I move the wood to the next key, I am losing the tooth that preceded it. So when I am done, all the teeth have been knocked out. In looking at the comments on the Rockler website, I think I saw at least one comment that said you need to use a spiral bit, which I am not. I was also wondering if it was a simple matter of my going too fast with the cut ? I am using 1x4 pine if that makes any difference rather than a hardwood. I have also found that the Rocker jig, being very light weight is not real easy to keep in the track, so I am finding it difficult to get the same height on each rout also. But that is more me than anything else.
Gary
gjackson52 is offline
post #2 of 20 (permalink) Old 08-06-2015, 12:49 PM
First Name: 4D
If you are cutting the fingers in the side grain then that is why you are having trouble. Box joints should only be cut in the end grain of boards. If the grain is squirrelly then you may still have some chipout even when cutting the fingers in end grain.
4DThinker is offline
post #3 of 20 (permalink) Old 08-06-2015, 12:54 PM Thread Starter
gjackson52's Avatar
First Name: Gary
Side grain...yes, I was doing that. I will try the end and see if that works better. What I was doing was routing on the long edge to make a "guide" to see if I would have full fingers on the end of the board using 1/2" box joints. Thank you.
Gary
post #4 of 20 (permalink) Old 08-06-2015, 01:08 PM
Nickp's Avatar
First Name: Nick
Gary
Does this mean the bit is cutting the pin out when you move it or that it is chipping a small piece of the wood...?
If the bit is cutting the entire pin out it sounds like a positioning error during setup. The spacing should be 1/2" for the bit (assuming that is the bit size), a space equal to the bit diameter and then the guide. Is this the way you set it up...? If the bit winds up right next to the guide, it will cut everything out as you described.
gjackson52 likes this.
Nick
GIVE A MAN a fish and you feed him for a day.
Teach him how to fish and you feed him for his life time.
Nickp is online now
post #5 of 20 (permalink) Old 08-06-2015, 01:44 PM
Gary, you can make dovetails, finger and box joints with the grain on an angle but not parallel.
Solid carbide spiral up cut bits make a huge difference in your results. Be sure to use a backer board to help prevent tear out.
timbertailor and gjackson52 like this.
post #6 of 20 (permalink) Old 08-06-2015, 01:47 PM Thread Starter
gjackson52's Avatar
First Name: Gary
I am going to have to go back and double check to make sure it was set up ok. Thank you for pointing that out.
Gary
post #7 of 20 (permalink) Old 08-06-2015, 07:54 PM Thread Starter
gjackson52's Avatar
First Name: Gary
I went and doubled checked the setup, it seemed fine according to the setup guide from Rockler. I am using the 1/2" key that Rocker supplies and I have a 1/2" gap from the router bit for the finger. I also looked closer at the grain. I noticed that ends that are breaking out had what I would call a swirl or sort of circular grain that leads to a knot. This seems to be hugely prone to chip out. As luck would have it, 3 of the 4 boards I have cut out for this purpose have that type of grain. So I am thinking that I need to go to plan B...as soon as I think of what that is lol Maybe pocket holes.
Thanks guys !
Gary
P.S. Yes, I was using a backer board. Would it help to also put a board in front of my piece for support ?
post #8 of 20 (permalink) Old 08-06-2015, 08:03 PM
No Gary, a spiral bit cuts cleanly but the back edge needs the support to prevent tear out. You should invest in three solid carbide spiral up cut bits; 1/4", 3/8" and 1/2". MLCS offers a set of these three for a reasonable price.
post #9 of 20 (permalink) Old 08-07-2015, 09:20 AM
Backer board and spiral up cut bit of Carbide will end many of your problems. If you think about it, you can see that the area swirling around a knot gets more dense and harder, a little like glass. So when you cut into that zone, it is likely to chip or break chunks away.
Nifty hobby, woodworking is.
DesertRatTom is online now
post #10 of 20 (permalink) Old 08-07-2015, 10:25 AM Thread Starter
gjackson52's Avatar
First Name: Gary
Yes, it is a nifty hobby and definitely has a learning curve. But having a resourse like you guys does take a lot of the frustration out. Except the budget committee is getting a little unhappy with me. :-)
Gary
Roy Drake likes this.
For Sale: Whiteside 3390 Fine Finger Joint Router Bit jvg2259 Woodworking Classifieds 4 07-02-2015 10:31 AM
3/4in Depth cut rabbeting bit Rell Router Bits - Types and Usage 5 01-20-2012 12:16 PM
How to Make A Stand Alone Bookend Set learnexperience Jigs and Fixtures 2 08-04-2011 04:22 AM
Router Bit Set for Raised Panel Doors Hoss McGr Table-mounted Routing 8 10-17-2009 05:17 PM
