Cove cuts ? - Router Forums
post #1 of 9 (permalink) Old 08-20-2015, 12:18 PM Thread Starter
First Name: Al
Default Cove cuts ?
I need to cut 1/2" stopped coves on the corners of a piece of oak 2" by 4". I intend to make several passes. Would it be better to raise the bit to it's full height and move the fence back gradually or have the fence back fully and raise the bit gradually, or does it matter ? Oldrusty
oldrusty is offline
post #2 of 9 (permalink) Old 08-20-2015, 12:39 PM
Unless it's a really large cove I usually go for one pass. Is there a typo? I read that as 2" x 4". That's a really small piece for a stopped cove.
post #3 of 9 (permalink) Old 08-20-2015, 12:43 PM
set the fence to final cut...
raise the bit progressively for the cuts...
post #4 of 9 (permalink) Old 08-20-2015, 01:12 PM
PhilBa's Avatar
First Name: phil
that's a small piece for any cut on a router table. I flinch just thinking about it.
Visit my shop website.
PhilBa is offline
post #5 of 9 (permalink) Old 08-20-2015, 01:20 PM
there are a slew of ways to hold small parts....
#1 method...
post #6 of 9 (permalink) Old 08-20-2015, 01:33 PM Thread Starter
First Name: Al
Charles, I'm not sure what you mean by a small piece. The measurements are just thickness and width when viewed from the end, the length can be any measurement. Al
oldrusty is offline
post #7 of 9 (permalink) Old 08-20-2015, 02:29 PM
MT Stringer's Avatar
I use push blocks whenever I can to hold the piece down on the table.
I like the idea of raising the cutter a little at a time and make several passes until you get the desired result.
That was my method when I built the base trim for the liquor cabinet.
Name:	Cove molding.jpg
MT Stringer is offline
post #8 of 9 (permalink) Old 08-20-2015, 06:37 PM
hawkeye10's Avatar
First Name: Don
I agree with Stick. That way after each cut you can check your progress. I have stopped at a certian point that I liked better than the full cut.
Don
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #9 of 9 (permalink) Old 08-20-2015, 07:47 PM
Okay. To me the measurements meant width by length. 3/4" was what I assumed the thickness to be. Still, a 1/2" cove is not a particularly large profile for a router to cut unless it is a quite small router. You might want to leave a small finish cut for the last pass to finish with and hopefully achieve a better finish but as Stick pointed out recently that may dull your bit faster so you may have to decide where the best trade off is.
O.K. Need To Talk About Incra Jointery cuts.... Jerry Bowen Tools and Woodworking 9 01-04-2015 12:34 PM
Cross Cuts Differ From Rip Cuts... Jerry Bowen Tools and Woodworking 9 07-15-2013 11:27 AM
Jerry's latest observation on accurate cross cuts Jerry Bowen Tools and Woodworking 32 10-15-2012 10:34 PM
Matching cove and roundover cuts ashrivastava Router Bits - Types and Usage 3 12-26-2009 11:36 AM
cove and round over cuts for folding table top ashrivastava Router Bits - Types and Usage 3 12-05-2009 10:30 PM
