Delta 34-184 for raised panels...? - Router Forums
post #1 of 8 (permalink) Old 08-28-2015, 12:50 PM Thread Starter
Nickp's Avatar
First Name: Nick
Default Delta 34-184 for raised panels...?
Your opinion, please...
Considering tenoning jig and vertical panel bit for next project...bathroom vanity.
More questions later but prepping tools first...
Is there room under the backstop for the bit...
Will the panel be held securely...
Thanks in advance...
Nickp is offline
post #2 of 8 (permalink) Old 08-28-2015, 01:10 PM
that's best one on the market...
have one... not used much at all.. doesn't like long vertical pieces all that well...
you planing on using it on the RT or TS???
it's not for panels... it's for the rails and stiles and cutting their tenons only...
cut your tenons on the TS and use your dado set to do it...
post #3 of 8 (permalink) Old 08-28-2015, 02:17 PM Thread Starter
Nickp's Avatar
First Name: Nick
RT...panels might be 20 x 12...thinking vertical bit...
Nickp is offline
post #4 of 8 (permalink) Old 08-28-2015, 05:03 PM
that tool is not the rigt one for the job...
a tall fence is...
post #5 of 8 (permalink) Old 08-29-2015, 08:20 AM
First Name: Gary
Nick, NO! it's not for panels. When working with panels they must be against a tall sturdy fence using feather boards, either using a table saw or a router table. The Delta 34-184 jig is extremely accurate when making tenons or grooves on the end of a board.
gmercer_48083 is offline
post #6 of 8 (permalink) Old 08-29-2015, 08:45 AM
Gene Howe's Avatar
First Name: Gene
A high fence and tilted blade is a much safer option.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #7 of 8 (permalink) Old 08-29-2015, 11:12 AM Thread Starter
Nickp's Avatar
First Name: Nick
It's unanimous then...idea scrapped...tall fence it is...
Thank you all for setting me straight...
Nick
Nickp is offline
post #8 of 8 (permalink) Old 08-30-2015, 08:07 AM
First Name: Gary
Default Tenon jig
The Delta Tenon tool would be a welcome accessory to your table saw, and is only limited by ceiling height. Each time I've used mine I am thankful I bought it. It's accurate and easy to set up and safe to use. A solid tool.
Raised Panels: Router vs. Table Saw??? PorterCable690 Jigs and Fixtures 77 03-03-2014 07:34 AM
Glueing panels to Stiles and Rails Kelwing2132 Tools and Woodworking 4 12-23-2011 09:07 AM
Panels: Spaceballs being compressed on assembly? dawziecat Tools and Woodworking 4 02-26-2010 03:28 PM
finishing raised panels Padawan Learner Tools and Woodworking 9 11-11-2009 03:36 PM
Router for raised panels Jtomwoods Table-mounted Routing 5 11-03-2009 07:20 PM
