Joint Matic - Router Forums
 1Likes
  • 1 Post By Mike
post #1 of 3 (permalink) Old 09-27-2015, 07:38 PM Thread Starter
Default Joint Matic
I have a joint matic and discovered an adjustment problem with a black and decker router and my craftsman router. There is not enough depth adjustment to get past the 1 inch dust collection system. I took off the red adjusting ring from the craftsman router that allowed me to get the adjustment I needed to use the machine. does anyone else have a joint and how did you solve your problem? I also considered a router extension but was concerned about run out. I have only made box joints with the machine and it works well. Let me know if you found a better solution. Larry
lalkie is offline
post #2 of 3 (permalink) Old 09-27-2015, 09:15 PM
Larry, if you have a 1-1/2" clearance hole a Musclechuck adds about 5/8" cutting depth. Is that enough to solve your issue?
The Shopsmith Joint Matic is a horizontal router table.
Sam Blount likes this.
post #3 of 3 (permalink) Old 09-28-2015, 07:33 PM Thread Starter
It is I will look into the muscle chuck. Thanks Larry
lalkie is offline
Doesn't make sense to me 163481 Tools and Woodworking 14 09-22-2015 06:31 PM
Centering pins/slots with the box joint sled Gaffboat Jigs and Fixtures 7 09-22-2014 07:39 PM
The difference between a box joint and a finger joint bit Mike Router Bits - Types and Usage 6 09-08-2014 01:21 PM
Groove and Tennon Joint Construction neville9999 General Routing 3 11-19-2013 10:15 AM
The first through dovetail joint by AKEDA Benny LaBaw Jigs and Fixtures 9 12-14-2009 08:01 AM
