Rack build - which technique - Router Forums
post #1 of 3 (permalink) Old 10-06-2015, 07:18 AM Thread Starter
Default Rack build - which technique
Hello, thanks in advance. I am building a rack and as you can see in the video I can go about it one of three ways.
I have practiced and when I use a roundover bit and free hand the whole side including the cutouts I get some burning. I am thinking maybe I should just roundover the whole edge first, then come in and individually do the cutouts.
Here is me explaining in a short clip....I post the link due to less than 10 posts but go to youtube.com/watch?v=58JaQ3iFQOM&feature=youtu.be
lovethepirk is offline
post #2 of 3 (permalink) Old 10-06-2015, 08:08 AM
Welcome to the forum. Burning is usually caused by dull and/or dirty bits and too slow a feed speed. If you using something like a round over you can compensate by not lowering the bit all the way for the first cut and then take a light finish cut.
post #3 of 3 (permalink) Old 10-06-2015, 09:37 AM
If you're making multiples, drill the holes in the center of the part and round over the edges of the holes, both sides. Split the board into two halves. To get the roundover on the edge, use the router table but with the board on end and you shouldn't have a problem with the cutter dropping into the holes.
tomp913 is offline
Group Cyclone Dust Collector Build schnewj Project Plans and How To 99 08-23-2015 09:27 PM
Built in book shelf/ Shopnotes Clamp rack fasttruck860 Show N' Tell 14 09-25-2009 10:40 PM
