rough surface on round over - Router Forums
 6Likes
post #1 of 18 (permalink) Old 10-06-2015, 07:12 PM Thread Starter
Default rough surface on round over
Hi, I got rid of my burning by doing 2 passes on the round over bit, cool!
Anyway, when I am entering a round over cut the beginning cut is smooth(seen on the right in the picture) then as I am moving the wood from right to left throughout the cutout when it exits I get a little rough surface as seen on the right side of the cutout below.
Any tips? More pressure, less, faster feed?
Murtu01 likes this.
lovethepirk is offline
post #2 of 18 (permalink) Old 10-06-2015, 09:22 PM
that's tear out...
bit is getting dull.
bit needs cleaning....
you could try climb cutting on the last pass...
post #3 of 18 (permalink) Old 10-06-2015, 09:27 PM
First Name: Terry
This may be incorrect but I'm thinking I read about it in some old old woodworking book when I was young (65 now). The cut being smooth because the cutter is following the direction the tree grew from the ground up and the rough is cutting against it.- Or possibly I may just be having one of those "moments" : )
I've run into the same thing in every instance no matter HSS or various carbide. Sharpness of the cutter doesn't appear to be a factor. Back routing has not helped (much) and the speed of the router and feed doesn't help all that much either. I have found the higher the moisture content of the wood the worse it is. I suspect a harder very tight grained wood should show less.
I don't mean to infer its like a rip cut and cross cut using a saw
Semipro likes this.
McHugh is offline
post #4 of 18 (permalink) Old 10-06-2015, 09:47 PM
A newer better bit mightt help like Stick is suggesting. Some of the better ones have a shear angle on the cutter meaning that the cutting edge is at an angle to the shaft instead of inline with it. The shear angle slices instead of scraping. As the saying goes, you get what you pay for.
post #5 of 18 (permalink) Old 10-06-2015, 10:29 PM
Ghidrah's Avatar
First Name: Ronald
How's the cut between your fingers, is it rough too? Whenever my bits dull they tend to burn or burnish
Ghidrah is offline
post #6 of 18 (permalink) Old 10-07-2015, 01:22 AM Thread Starter
Thanks for the pdf's. I think after reading that climb cut warning I will stay away as I am a novice.
The router bit is brand spanking new and my straight cuts and gently curves are like a baby's azz. The only problem I am having now is when I exit that cutout/finger I get a little tear out as you said. It has helped to speed up the exit a little. I got after it with some sand paper and cleaned it up, but I was just wondering if there is a technique to eliminate this.
What I noticed is that the guide bearing revolves smoothly when I enter the cut and that is when the cut is smooth, when I am following the curve out of the finger the bearing seems to not revolve as well so somehow its losing contact a little. More pressure didn't seem to work as well as just a faster feed at the exit.
Tagwatts1 likes this.
post #7 of 18 (permalink) Old 10-07-2015, 01:52 AM
close the opening w/ a piece of scrap...
route the cup 1st... remove the scrap and then do the straight edge...
what brand of bit are you using....
post #8 of 18 (permalink) Old 10-07-2015, 04:32 AM
toto's Avatar
First Name: Paul
Have you tried a different type of wood,i find this seems to happen to me when i am using sycamore but ok on ash ,oak, beech etc
mgmine and Roy Drake like this.
toto is offline
post #9 of 18 (permalink) Old 10-07-2015, 05:06 AM
you could move to the head of the class and go w/ a Freus Quadra Cut RO bit...
Freud Tools | 1/2" Radius Rounding Over Bit (Quadra-Cut)
post #10 of 18 (permalink) Old 10-07-2015, 07:20 AM Thread Starter
I'm using this quarter inch bit:
amazon.com/gp/product/B000LBIWOE?psc=1&redirect=true&ref_=oh_aui_detailp age_o00_s00
I'm sure it's a cheapy, I may try that Freud, I assume it's the cream of the crop. Also, I may try different wood, I think I am working with Pine right now. I'm doing a test run of my build and just grabbed some quick sheets at Lowes
Coping with quarter round Gaffboat Jigs and Fixtures 13 06-28-2015 01:24 PM
SS. Rough Cuts with a skill saw AzOwl Tools and Woodworking 15 03-15-2015 06:31 PM
Would our academic members like to comment harrysin Lobby 2096 01-30-2015 02:54 PM
MDF and Routers Grootser General Routing 11 11-02-2013 01:11 PM
Looking to commission woodworker for round end table Hockeystyx Tools and Woodworking 1 10-26-2009 11:14 AM
