Bosch 1615EVS switch problems - Router Forums
post #1 of 5 (permalink) Old 11-01-2015, 08:01 PM Thread Starter
First Name: Cecil
Question Bosch 1615EVS switch problems
I use the 1615EVS in a table but I have trouble with dust getting into the switch. So far I have been able to disassemble the switch and clean it. However this is a pain. Does anyone know of a sealed switch or have any suggestion on how to correct this problem?
cbdeajr is offline
post #2 of 5 (permalink) Old 11-01-2015, 08:07 PM
call Bosch tech support...
they may have a solution...
Stick486 is offline
post #3 of 5 (permalink) Old 11-01-2015, 10:24 PM
I remember a few years ago some forum members contacting Bosch CS about that problem and Bosch sent them a redesigned switch at no cost. I can't remember which model it was but that may not matter.
post #4 of 5 (permalink) Old 11-01-2015, 10:55 PM
yes...
they have been known to do that...
Stick486 is offline
post #5 of 5 (permalink) Old 11-02-2015, 08:13 AM
First Name: PAD3
About two years ago I had the same problem which was intermittent. I called Bosch and they sent a replacement switch at no charge and the problem was cured.
PAD3 is offline
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Bosch 1615evs Router lenville General Routing 8 09-17-2011 08:39 AM
Dewalt or Bosch??? jrwoodbutcher Starting Off 5 12-23-2010 10:18 AM
Bosch Router Switch Problem bill kay General Routing 41 11-19-2010 08:29 AM
Bosch 1617EVSPK Switch problems grb336 General Routing 11 09-22-2009 10:27 AM
