Jamb Extension Routing - Router Forums
 4Likes
  • 1 Post By Cherryville Chuck
  • 1 Post By PhilBa
  • 1 Post By Stick486
  • 1 Post By Herb Stoops
post #1 of 7 (permalink) Old 12-09-2015, 03:14 PM Thread Starter
First Name: Jeff
Default Jamb Extension Routing
Anderson Bow window jamb extensions. See attached pic. I want to machine jamb extensions in oak to replace the pine that came with window. Want to match oak sill I made.
Looking for suggestions on how best to machine this specifically the T&G end at an angle. Any help would be much appreciated.
Thanks, Jeff
golfisher is offline
post #2 of 7 (permalink) Old 12-09-2015, 03:31 PM
I would probably do it on a table saw. It's made to angle the cut and routers aren't. To do it with a router you would have to make at least 2 jigs. With a TS you just set the tilt to the angle you want.
Maybe I misunderstand what you want but if that piece is the sill plate then it looks like you plan on joining another piece to it down slope and that will not be a good idea.
neville9999 likes this.
post #3 of 7 (permalink) Old 12-09-2015, 04:32 PM
PhilBa's Avatar
First Name: phil
Yeah, I agree with chuck, that would be a lot easier on a TS. Once you have the angle of the blade set, you won't need to change it, just the height. That assumes your TS fence face is perpendicular to the table. It's still a bit tricky - think through the cut order. I'd probably do all the non through cuts first. You might need a sacrificial fence face to do the little notch.
PhilBa is offline
post #4 of 7 (permalink) Old 12-09-2015, 04:50 PM
that's table saw work...
Herb Stoops likes this.
post #5 of 7 (permalink) Old 12-10-2015, 11:52 AM Thread Starter
First Name: Jeff
The pic is of vertical extension jamb laid down of which I want to duplicate. Thanks for the help!
post #6 of 7 (permalink) Old 12-10-2015, 11:53 AM Thread Starter
First Name: Jeff
Thanks!
post #7 of 7 (permalink) Old 12-10-2015, 06:53 PM
Jeff, I would cut the angle shown on the top right side of the picture on the table saw.
Then use a dado blade to cut the tongue ,by fist holding the angle you just cut against the fence and set the fence to cut the front of the tongue.
Then move the fence toward the blade and cut the back of the tongue.
You will probably have to use a sacrificial fence to keep the dado blade from nicking the table saw fence on the last cut.
Also I would make some guides to stabilize the piece as I fed it thru the saw as to not tip it and throw off the cut.
golfisher likes this.
Herb Stoops is offline
Damaged Door Jamb tomp913 DIY and Renovation 42 10-29-2015 08:02 PM
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 10:33 AM
old person new to routing in wood sailer670 New Member Introductions 12 12-13-2014 08:31 PM
Use of template Guides cutter79 Guide Bushings and Templates 6 08-21-2013 04:18 AM
Craftsman table saw routing extension mikey_sl Tools and Woodworking 5 09-19-2005 10:26 PM
