1.5" Thick Box Joints w/ Incra LS Table, How? - Router Forums
 2Likes
  • 1 Post By bcfunburst
  • 1 Post By PhilBa
post #1 of 4 (permalink) Old 01-03-2016, 11:41 AM Thread Starter
First Name: Irish
Default 1.5" Thick Box Joints w/ Incra LS Table, How?
I "want" to make legs out of glued 3/4"x3" hardwood, making the legs 1.5"x3". They will be 18" tall and 16" wide like the pic below.
My question is the joining aspect. How can I make a 1.5" deep box joint? Is that even necessary? Will be supporting a 50"x20"x2" slab of black walnut. Making a coffee table. Other leg will be a recessed 3"x12" piece of oak.
For the boxjoint, Can I just keep raising the bit and make passes? What bit?
I dont have a band saw or a table saw jig.
Pic of legs I want to make out of wood.
Psychbiker is offline
post #2 of 4 (permalink) Old 01-03-2016, 01:00 PM
bcfunburst's Avatar
First Name: Reg
Default Box Joint
Welcome to The Forum . Hard to answer without knowing your experience level. I am looking at the photos you posted. Box joints are OK for making the leg assemblies and I would use a 1/2" straight bit w 1/2" shank, on a Router Table using a jig. You may want to consider some sort of reinforcement under the table to help stop that pesky Wracking hazard. I think even 3" wide hardwood isn't as strong as 3" wide steel leg assemblies. You will also find a lot of helpful ideas and instructions if you search out your questions on YouTube! Hope this helps you to have more fun with woodworking.
Murtu01 likes this.
"Even bad decisions make good stories"
<bcfunburst>
bcfunburst is offline
post #3 of 4 (permalink) Old 01-03-2016, 01:44 PM
PhilBa's Avatar
First Name: phil
How big are your box joint fingers (er, hope that term doesn't spark another argument)? Given that the LS allows repeatable positioning, multiple passes at increasing depths will probably be ok though you might not wind up with super tight fingers. Since the board isn't that wide, you can probably get excellent contact just by clamping across the fingers.
By the way, you aren't limited to your router bit width as the finger size. Here's an example template that uses a 1/2" bit to make 5/8" fingers. Note that it shows where you make multiple passes to get the right width finger/slot. If you have an accurate printer, you can cut that strip out, reinforce it with clear tape and slide it into your LS.
Murtu01 likes this.
Visit my shop website.
PhilBa is offline
post #4 of 4 (permalink) Old 01-03-2016, 02:43 PM
I'm with Reg on the racking issue. A square or rectangle easily become a parallelogram with racking force applied. A trapezoid is much stronger but you would probably be wanting to use a table saw to make that joint.
More fun with box joints Gaffboat Show N' Tell 17 04-07-2015 09:27 PM
Incra Table and Positioner Buckyoneshot Table-mounted Routing 22 12-29-2014 07:32 PM
Yet another router table build ... JohnBFisher Table-mounted Routing 23 11-13-2014 11:33 AM
Table saw or router table for best box joint ? RainMan 2.0 Jigs and Fixtures 18 09-15-2014 12:16 AM
Incra Ultra How-To (Box Joints + Other Stuff) Nickbee Show N' Tell 17 06-22-2009 12:42 PM
