Rotating Insert Rings - Router Forums
 10Likes
post #1 of 13 (permalink) Old 01-21-2016, 09:20 AM Thread Starter
First Name: Bob
Send a message via AIM to bob156235
Default Rotating Insert Rings
My top/fence/plate is from Rockler. One thing I dislike are handling the three tiny screws that hold in the various sized insert rings, and the required fussing to seat them flush every time. Seems like the smallest bits of sawdust prevents them from seating properly, plus, "snugging them down" repeatedly roughs up the cross slot and forms tiny ridges which catches the boards sliding over them. Where can I buy a new plate with rotating insert rings instead of the ones that screw in? I have only seen these type rings marketed with a router lift.
I'd have a tendancy to change these more often to better reflect the bit size if changing them were more user friendly. My big Triton would also benefit by the better dust collection too, which suffers from sawdust-clogged height-adjusting (falls down in spurts when lowering from above table). I've cleaned out the mechanism twice before which didn't alieviate the problem, but only helps. Anyhow, any leads? Thx.
bob156235 is offline
post #2 of 13 (permalink) Old 01-21-2016, 10:07 AM
Rogerdodge's Avatar
First Name: Roger
I have a UJK plate and rings here in the UK, but I think Jessem do a similar style set up in the USA.
INSERT RING SETS
Rog
Been at sea most of my life and still all at sea now.
Sometimes I sits and thinks and sometimes I just sits .
(M Twain)
Rogerdodge is offline
post #3 of 13 (permalink) Old 01-21-2016, 10:19 AM
Bob, you will find pates like that at any woodworking vendor. The best price out there is the $13 Grizzly T10432047. This is not a twist in version, the center rings snap in very snugly.
jw2170 likes this.
post #4 of 13 (permalink) Old 01-21-2016, 11:50 PM
Google Twist Lock router table inserts. I have the Rockler setup too and always find it annoying to have to mess with those screws. My router hero is Mark Sommerfeld, who has the twist lock setup, sooooo much easier. I'm going to buy a new plate, but the Rockler plate is an inch sorter in the sort dimension that the plates I've found, which means its rabbit time. At least I there are plates already drilled for the Triton. There goes another hundred bucks.
https://www.bing.com/search?q=Twist+...ZI&form=MOZSBR
I'm likely to get the Woodpecker unit. Wish Rockler would go to the Twist Lock system and put out a plate that fits their table.
I just ordered the Woodpecker plate and their template.
DesertRatTom is online now
post #5 of 13 (permalink) Old 01-21-2016, 11:55 PM
Had trouble posting this pix of the Woodpecker plate and twist lock inserts. Second try did it.
It comes with the inserts shown, but you can also order a more extensive set.
gjackson52 likes this.
post #6 of 13 (permalink) Old 01-22-2016, 05:48 AM
First Name: Larry
My inserts are held in with rare earth magnets. Very east to change.
Knot working is online now
post #7 of 13 (permalink) Old 01-22-2016, 09:42 AM
Did you set the magnets yourself? Glued them to the inserts, I presume. Very interesting idea! Tell us the details, please.
post #8 of 13 (permalink) Old 01-22-2016, 11:16 AM
Country: Mexico
First Name: Joseph Anthony
Question
I have a Rockler lift, do those insert rings sets (all mentioned above) will work in my lift?
RÖENTGEEP is offline
post #9 of 13 (permalink) Old 01-22-2016, 01:54 PM
PhilBa's Avatar
First Name: phil
I have them too - Incra/JessEm Mast-R-Lift II. Don't think you can add those on aftermarket. I love the way the magnets snap the ring in place. No fussing at all.
RainMan 2.0 likes this.
Visit my shop website.
PhilBa is offline
post #10 of 13 (permalink) Old 01-22-2016, 03:10 PM
RainMan 2.0's Avatar
Originally Posted by philba View Post
i have them too - incra/jessem mast-r-lift ii. Don't think you can add those on aftermarket. I love the way the magnets snap the ring in place. No fussing at all.
+2
Ok ,I never insulate
RainMan 2.0 is online now
what size insert rings for pc guide bushings? Goblu Guide Bushings and Templates 5 03-03-2015 05:22 AM
UJK Plate Insert Rings. Rogerdodge Table-mounted Routing 1 06-24-2014 12:18 PM
Made some "wooden" router table insert rings Burke Show N' Tell 8 10-01-2013 03:39 PM
Router table insert rings lower than table top jmoore65 Table-mounted Routing 10 07-11-2011 10:12 AM
Tweaking CMT aluminum insert rings? AlanZ Table-mounted Routing 7 01-09-2009 05:14 PM
