Climb Cutting - Router Forums
 7Likes
post #1 of 11 (permalink) Old 02-09-2016, 09:41 AM Thread Starter
berry's Avatar
First Name: Berry
Default Climb Cutting
I'm routing the circumference an elliptical piece and it's clear I'm having climb cutting issues. I wondered if someone could point me to a thread that discusses the "how-to's" of climb cutting with a table mounted router.
Thanks for reading.
May the grain be ever in your favor.
berry is offline
post #2 of 11 (permalink) Old 02-09-2016, 09:58 AM
Thanks for reading.
What is it you are cutting,do you HAVE to climb cut it? Is it free hand or on a table?
Herb Stoops is online now
post #3 of 11 (permalink) Old 02-09-2016, 10:07 AM
I'm not sure there is such a thing Berry but I occasionally do it at the corners of a piece where I'm likely to get tearout especially on tearout prone woods like red cedar. I'm not really sure how you mean that though. Are you routing a profile or cutting the shape out of a larger piece? Normally you should be starting from the right side of the table and feed the piece into the bit and then rotate it. Can you give more details?
berry likes this.
post #4 of 11 (permalink) Old 02-09-2016, 11:59 AM
PhilBa's Avatar
First Name: phil
It makes sense to climb when you can't use a backing to prevent tearout. I had to do it when rounding over the edges of the router bowl I posted recently in show and tell. The way to avoid the runaway cut problem is to take small climbing bites in the "normal" (i.e. non climb direction). See the picture.
Also, a spiral bit helps a lot. I think a shear would too but haven't tried it.
edit: fixed picture
Name:	climb cut 1.png
berry likes this.
Visit my shop website.
PhilBa is offline
post #5 of 11 (permalink) Old 02-09-2016, 12:23 PM Thread Starter
berry's Avatar
First Name: Berry
This is a small piece, the base/stand for a little scroll saw project for Valentine's Day. The view is showing the bottom of the stand.
The stock is cedar I was trying to cut a chamfer on the bottom of the stand and then I wanted to cut a profile on the top edge. The tear-out was lots worse before I sanded. And it kicked back quite a bit so I'm looking for help.
Thanks again.
berry is offline
post #6 of 11 (permalink) Old 02-09-2016, 12:31 PM
Thanks for reading.
see if these help...
Name:	ROUTER FEED DIRECTION 1.jpg
post #7 of 11 (permalink) Old 02-09-2016, 12:44 PM
PhilBa's Avatar
First Name: phil
Berry, you might want to take smaller bites in several passes as well. That looks like a fairly large cut.
Herb Stoops likes this.
PhilBa is offline
post #8 of 11 (permalink) Old 02-09-2016, 04:46 PM
Berry what is happening is you are cutting against the grain, and the bit is digging in. I have found that the only way I can do that is to do as Phil says and do small increments of height on your cuts.
I run into this on my lock shackles and have overcome it by raising the bit 1/32" at a pass. It takes longer but works without grabbing a chunk out or throwing the piece across the room,or worse yet ruining the piece.
berry likes this.
post #9 of 11 (permalink) Old 02-10-2016, 08:50 AM
Wildwood's Avatar
Country: South Africa
First Name: Rob
In these sort of situations I identify the areas which are going to give trouble, and do a series of controlled shallow climb cuts, on these areas only, till the bearing makes contact. The rest is routed in the normal direction.
Wildwood is offline
post #10 of 11 (permalink) Old 02-10-2016, 10:31 AM
I agree with this. On several occasions I have to hand work these spots with a file and hard sanding block, only takes a moment and comes out as good as the rest of the cuts.
Sometimes power tools do not work for everything and I have to resort to doing some hand work, But I guess thats the fate of a woodworker.
Wildwood likes this.
Climb cutting Cherryville Chuck Shop Safety 13 06-01-2014 10:32 AM
Router speeds and climb cutting questions. Duane Bledsoe General Routing 9 01-19-2013 08:19 PM
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 01:29 PM
Climbing, climb cutting TWheels Tools and Woodworking 9 08-27-2009 12:10 PM
