Triton Plunge Lock lever not locking - Router Forums
 1Likes
  • 1 Post By paduke
post #1 of 2 (permalink) Old 02-11-2016, 07:01 PM Thread Starter
Default Triton Plunge Lock lever not locking
I have a new Triton TRA001. I cannot get the plunge lock lever tight enough. As soon as I power the router on the bit sinks down. I took the lever handle off and used a wrench. The bolt is bottomed out and still the plunger moves up and down. Anyone else had this problem? I must be doing something wrong.
hardway is offline
post #2 of 2 (permalink) Old 02-11-2016, 09:05 PM
paduke's Avatar
Tighten lever
loosen screw until you can rotate lever counter clockwise
tighten lever again
it should work properly
there is a limit on the lever's movement sometimes the screw loosens then the lever wobbles around out of position Its happened to me before
JamesLybarger likes this.
paduke is offline
Locking lever mod for Craftsman 315.296210 ArTrvlr General Routing 7 01-05-2016 12:25 PM
Looking for Craftsman router locking lever spring jimmunnkey General Routing 5 09-17-2013 12:34 AM
Triton Routers PeterGee Portable Routing 38 01-15-2013 09:32 PM
Craftsman plunge router problem Edmarzo General Routing 2 07-21-2008 09:40 AM
Triton 3 1/4 HP plunge router $299 CDN CanuckBeaver The Bargain Bin 10 04-15-2006 11:41 AM
