Kreg ≠ Incra...specifically the Kreg Swing Stop! - Router Forums
 30Likes
post #1 of 20 (permalink) Old 02-16-2016, 10:11 AM Thread Starter
niswanger's Avatar
First Name: Roy
Default Kreg ≠ Incra...specifically the Kreg Swing Stop!
Hey gang,
I wasn't sure where to put this thread (looked in the lobby but I saw too many topics about Windows 10 and hearing loss )
First, I just wanted to plug for Kreg customer service, they have been fantastic!
Second, I wanted to use the Kreg Swing stop (pair of them) atop my Benchdog Pro Router Fence, but my fence does not have a t-track on the top, so I added one, specifically a combo graduated/T-track from Incra. I took my time and even tapped machine threads (#6) into the top of the fence. When it all came together I painfully found out that the Kreg Swing stop does not work well in this Incra T-slot track. In addition, nowhere on the Kreg Swing stop does it say "for use only with Kreg T-tracks. There is just far too much play. I wonder if this is the reason for a number of "too much play" negative reviews on amazon.com? Here's what I'm talking about:
So, I email Kreg with this video and they got back to me and wanted me to call them. Long of short, they sent me their Precision Router Fence System for free. Yes I said free!
Then I purchased their Precision Miter Gauge System and found that the nylon set screws to adjust the play in the slide were fitting too tight and darn near twisting under stress when screwing them into the miter bar. When I call and talked to Ben this morning he immediately said he as heard the same and they believe the set screws I a bit too large but since they haven't 100% determined the issue he sent me a whole new bar and extra adjustment screws, again for free.
Just passing on the incompatibility of the Kreg Swing Stop and other T-Tracks and the great customer service Kreg has offered me recently.
Thanks,
Roy
niswanger is offline
post #2 of 20 (permalink) Old 02-16-2016, 10:22 AM
First Name: Keith
Excellent information...thank you!
OK, fess up...which one of you clowns stole my sig? It was right here a second ago.
cocobolo1 is offline
post #3 of 20 (permalink) Old 02-16-2016, 10:27 AM
hawkeye10's Avatar
First Name: Don
I had a problem with a Kreg product and called them. They sent me a new part and the problem was solved.
PS- Kreg is a great company. That is my story and I am sticking to it.
billyjim and gjackson52 like this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #4 of 20 (permalink) Old 02-16-2016, 10:58 AM
PhilBa's Avatar
First Name: phil
This problem is a symptom of a bigger issue - general interoperability, or more precisely, lack thereof. Some of the Incra stops don't even work on different Incra products (LS fence vs miter gauge). The flip stop on my Incra miter gauge (1000HD) works great but doesn't fit the LS fence. Do those development teams actually talk to each other? I make a lot of stopped dados on my router table and a flip stop would be very useful.
My experience with various stops has convinced me to just make my own. I use 6/4 stock to make blocks and drill a hole at the right place to go into the T slot. But I'm still pondering how to make a usable flip stop for my LS. The flip stop on my Incra Miter gauge is actually pretty well made and works well on the miter. But, it has an "incremental positioning rack" that makes for 1/32" aligned positions. While that's supposed to be a feature, it's one I find more of a pain to use than not. The whole point of a flip stop is to be able to get the stop out of the way without removing it, not sure the incremental rack adds anything. Because of the rack, it doesn't fit anywhere else.
Nickp and niswanger like this.
Visit my shop website.
PhilBa is offline
post #5 of 20 (permalink) Old 02-16-2016, 06:32 PM
Gaffboat's Avatar
First Name: Oliver
@PhilBa
Here's my solution for a shop-built filp stop, Phil.
https://dl.dropboxusercontent.com/u/...n-sequence.gif
JFPNCM, TenGees, Nickp and 8 others like this.
Gaffboat is offline
post #6 of 20 (permalink) Old 02-16-2016, 07:08 PM
PhilBa's Avatar
First Name: phil
nice solution. but I would expect no less from you!
PhilBa is offline
post #7 of 20 (permalink) Old 02-16-2016, 07:30 PM
I find the "interoperability" issue a PITA! I bought Kreg T-track for my workbench, not really knowing that other tracks are not compatible with Kreg bolts. After investing in some hold-downs etc for the workbench, I decided to include some T-track in the router I am building. So I ordered some less-expensive T-track from Peachtree.
Needless to say, none of my Kreg bolts will fit my Peachtree track, in fact even the 1/4-20 bolt heads don't fit the Peachtree track properly because the mounting holes are not countersunk properly to all the screw heads to become flush with the track.
Oh, and I discovered that the miter track on my old (ca. 1983) Craftsman table saw is non-standard, so I can't use an after-market miter gauge or sled ;-(
Is there an easy solution, or is this a PC vs Mac kind of issue?
<Chas>
I'll burn that bridge when I come to it
CharlesWebster is offline
post #8 of 20 (permalink) Old 02-16-2016, 08:34 PM
PhilBa's Avatar
First Name: phil
The craftsman miter track issue is the worst by far. A perfect example of deliberate "lock-in". Arrogance proceeded their downfall.
The peachtree track is easy to countersink so you can solve that problem. toilet bolts often work in the skinny tracks. and some incra tracks (in their miter gauge, iirc) only take #10 screw heads. but yeah, it's all a big PITA having to deal with it. I usually make sure tracks I get will take standard 1/4" bolts. If the seller doesn't show dimensions or otherwise say 1/4" bolt, I move on.
billyjim likes this.
PhilBa is offline
post #9 of 20 (permalink) Old 02-17-2016, 07:01 AM
Nickp's Avatar
First Name: Nick
Roy...watched your video a couple of times (nice, BTW) and wondered if you could loosen the hold down, twist in the larger boss and then clamp down...
Nick
Nickp is offline
post #10 of 20 (permalink) Old 02-17-2016, 07:18 AM Thread Starter
niswanger's Avatar
First Name: Roy
Yes Nick and it does bind up a little firmer, although it's not right because of 1. the flip stop is no longer square to the fence 2. with nominal pressure it will come out of lock and then be really loose.
-Roy
Kreg Miter Gauge vs. Incra Miter Gauge Jerry Bowen Tools and Woodworking 8 06-04-2012 08:58 AM
Input on Kreg vs. Incra Router Tables mjdorsam Portable Routing 5 03-27-2012 04:25 PM
Incra Right Angle Jig on Kreg Fence chalfke1 Jigs and Fixtures 9 03-07-2011 12:40 PM
