DIY miter :help: - Router Forums
 2Likes
  • 2 Post By Cherryville Chuck
post #1 of 7 (permalink) Old 02-22-2016, 04:11 PM Thread Starter
Knothead47's Avatar
Question DIY miter :help:
I have a bar from Woodcraft that fits the track on a Kreg bench top router table. What would be a good and accurate way to build a miter to rout the ends of boards? Could it be made to be adjustable for different angles? Thanks.
John T.
Knothead47 is offline
post #2 of 7 (permalink) Old 02-22-2016, 04:29 PM
Do you want to make a miter gauge,or sled for your router table and use this bar as a guide? I have not done that on a router table, I have always guided off the fence,and made a jig to clamp the piece to hold it while pushing it through the bit and have a sacrificial backup board.
My thought was that if the slot in the table was not perfectly parallel to the bit from end to end the cut might start right and end up wrong as it is clamped to the miter gauge.
Herb Stoops is offline
post #3 of 7 (permalink) Old 02-22-2016, 05:35 PM Thread Starter
Knothead47's Avatar
Herb, I'm wanting to make a miter or a sled, using the Incra bar. Here's the need: I started to make a necklace rack for SWMBO. I routed the beveled edge on the long sides with no trouble. When I tried to bevel the ends of the board, about 2-1/2 inches wide, I got a wavy edge. It would be nice if it could be 90 deg. and 45 deg. Probably not need any other angle. Thanks for the prompt reply.
John T.
post #4 of 7 (permalink) Old 02-22-2016, 05:45 PM
Nickp's Avatar
First Name: Nick
I would suggest more of a sled allowing you to clamp the piece and a backer. I would also suggest smaller bites...
The rotation of the bit would try to push the piece away as it enters...clamp will fix that...
Nick
Nickp is offline
post #5 of 7 (permalink) Old 02-22-2016, 05:59 PM
I also just use a pusher block against the fence, then it doesn`t matter if the fence isn`t square to the table. I watched the Marc Sommerfeld shaker door video the other day and that`s how he does it too. If you want clamping ability look in my uploads to see a way to do it with a push block.
Nickp and Herb Stoops like this.
post #6 of 7 (permalink) Old 02-22-2016, 08:20 PM
Chucks way is the best, clamp it to a push block and hold the push block tight to the fence. the push block will keep it square and also back up the cut to prevent tear out of the side grain. This is the way I do it too, just didn't know how to explain it.
post #7 of 7 (permalink) Old 02-23-2016, 08:59 AM Thread Starter
Knothead47's Avatar
I just looked at CV chuck's uploads. I found what he suggested: 11/20/15, coping sled for a Triton table. Got it and thanks to all!
John T.
Crosscut Fences II (Digital) MAFoElffen Tools and Woodworking 10 06-28-2013 08:37 PM
miter saw vs table saw w/ miter gauge Everend Tools and Woodworking 23 04-06-2013 09:07 PM
Saw C10FSH sliding compound miter saw kp91 Hitachi Manuals 6 03-28-2011 08:08 AM
For Sale: Ridgid 12" sliding miter saw - USED, works dovetail_65 Woodworking Classifieds 11 01-20-2011 11:28 PM
DIY miter saw fence: good idea? xvimbi Tools and Woodworking 12 11-29-2010 09:50 PM
