trouble routing for hinges - Router Forums
 13Likes
post #1 of 16 (permalink) Old 03-07-2016, 08:38 PM Thread Starter
First Name: Marc
Default trouble routing for hinges
Hi folks,
I am having a bit of a problem with matching the routs on the top and carcass. I am using stops on my table and if I set the stops for the bottom, to center on the carcass, the top does not match those stop settings. Confused? Me too. The top is swapped end for end which makes the dado off from the dado on the carcass. HELP!!
thanks
Crash
crash_landing is offline
post #2 of 16 (permalink) Old 03-07-2016, 08:46 PM
Originally Posted by crash_landing View Post
Hi folks,
thanks
Crash
yup...
what type/kind of hinges..
door style...
where are the routs.. door, carcass, both...
and how are you feeding a carcass to an RT???
you got a picture???
post #3 of 16 (permalink) Old 03-07-2016, 09:12 PM
Marco's Avatar
Marc, I don't use a RT for hinges. I can barely line them up when I can see what I am routing. Sounds pretty tricky to get it right. Good luck.
Galatians 5:13
Marco is offline
post #4 of 16 (permalink) Old 03-07-2016, 09:52 PM
OttoW's Avatar
First Name: Otto
I haven't tried routing for hinges before.
But I do have a question. Can you take the two parts line them up next to each other and us one jig to cut both at the sometime? It seams to me that doing so would align them without effort. Of course that would mean you would have to use the router handheld instead of a table but in my mind (disclaimer, I installed new flooring in my kitchen today and now I've been enjoying a few beers.)
I've been leaning Sketchup and did a quick sketch.
I'm not sure how the jig setup would go unless you're working with similar hinges often then you could cut a pattern the size of the hinge use a top bearing router bit as a guide and cut both hinge locations at the same time.
Again, I'm very new into woodworking and this is all in my mind I could be very well be wrong. Maybe someone can help us both out.
New guy looking for ideas.
OttoW is offline
post #5 of 16 (permalink) Old 03-07-2016, 10:21 PM
w/ so many cheap jigs and templates out there for routering hinges why go complex...
Ray Newman likes this.
post #6 of 16 (permalink) Old 03-07-2016, 10:33 PM
First Name: Keith
Hate to say it, but mallet and chisel and you're done in no time.
OK, fess up...which one of you clowns stole my sig? It was right here a second ago.
cocobolo1 is offline
post #7 of 16 (permalink) Old 03-07-2016, 11:01 PM
PhilBa's Avatar
First Name: phil
Hinges can be a challenge. I've tried a number of templates for routing the hinge mortise. By far the best for me is a simple rectangular cut out in template material to guide a hand held router with a bushing. Cut each mortise separately.
First, I clamp the lid and the base together and mark where the hinges will go on both. Then I separate them, clamp on my template and route each one in turn. See the picture. I usually bang one of these out for a specific hinge. By running a test route on it you make the recess that is the hinge length. Then line up the edges of that cut with the marks for where you want hinges to go. The cuts go really fast - like a minute to clamp the template and route each mortise.
You can make this template a lot more elaborate and adjustable if you want. However, I can bang out a task specific one like shown above in a short amount of time.
I have made a template to route both top and bottom at once but found that getting everything perfectly aligned took longer and was more fraught with potential error than just doing them one at a time.
Name:	hinge mortise template.png
Ray Newman, Semipro and OttoW like this.
Visit my shop website.
PhilBa is online now
post #8 of 16 (permalink) Old 03-07-2016, 11:03 PM
PhilBa's Avatar
First Name: phil
Yeah, I would prefer to do it that way but I have never been able to do a really clean hinge mortise that way.
post #9 of 16 (permalink) Old 03-07-2016, 11:09 PM
First Name: Johnny
I have a few templates, but they never seem to work right so I just line my pieces up, place the hinge in place then scribe around it with a knife and use a chisel. A really sharp chisel I might add.
JohnnyB60 is offline
post #10 of 16 (permalink) Old 03-07-2016, 11:12 PM
really sharp correctly sized chisels and a bit of practice...
vchiarelli and MYB like this.
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 10:33 AM
Routing Tutorials ModeratorTeam Guide Bushings and Templates 4 02-01-2015 09:37 AM
old person new to routing in wood sailer670 New Member Introductions 12 12-13-2014 08:31 PM
Trouble Pattern Routing - Help Appreciated marc82much Table-mounted Routing 21 05-06-2014 12:07 AM
Use of template Guides cutter79 Guide Bushings and Templates 6 08-21-2013 04:18 AM
