Shame on me. - Router Forums
 11Likes
  • 4 Post By oldrusty
  • 2 Post By MBurke
  • 5 Post By Stick486
post #1 of 9 (permalink) Old 03-12-2016, 01:17 PM Thread Starter
First Name: Al
Default Shame on me.
I am working with small pieces of maple "a first for me" that barely bridge the gap in my fence. Two and a half inches of wool and a one inch gap in the fence. Instead of taking the time to make a hardboard zero clearance profile of my bit I went ahead and made several passes and suffered the consequences of serious tear out. I then smartened up and made the zero profile device. What a difference. I have proved to myself that this technique really works. It's the first time I have worked with hardwood, it's whole different ball game. Oldrusty
oldrusty is offline
post #2 of 9 (permalink) Old 03-12-2016, 01:36 PM
Lucky thats wall that happend.
Deep Breath....slow down and make it safe :-)
Semipro and Herb Stoops like this.
MBurke is offline
post #3 of 9 (permalink) Old 03-12-2016, 01:37 PM
small part holder...
many other uses too...
Stick486 is offline
post #4 of 9 (permalink) Old 03-12-2016, 03:34 PM
Using a push block (a square piece of mdf, ply, particle board, or wood) also reduces or eliminates tearout and will also help keep the work piece more stable.
post #5 of 9 (permalink) Old 03-12-2016, 03:37 PM Thread Starter
First Name: Al
The problem wasn't "holding the pieces" as they were six inches long and two and a half across the end grain. I used s large backer board when cutting across the grain and a Grrriper with the grain so my hands were always clear of the bit. The problem was that as hard as I held the piece against the backer board and the fence, the moment it left the right hand fence at the finnish of the cut, it dipped fractionally towards the bit, leaving the protection of the backer board and causing small but annoying tear out. Anyway the hardboard jig solved the problem. Al
oldrusty is offline
post #6 of 9 (permalink) Old 03-12-2016, 03:45 PM
First Name: Keith
No harm done and you had it figured out in no time.
OK, fess up...which one of you clowns stole my sig? It was right here a second ago.
cocobolo1 is offline
post #7 of 9 (permalink) Old 03-12-2016, 05:17 PM
....taking the time to make a hardboard zero clearance profile of my bit
Always time well spent...It only has to be a strip of hardboard...
Sydney, Australia
jw2170 is offline
post #8 of 9 (permalink) Old 03-12-2016, 05:44 PM
JFPNCM's Avatar
First Name: Jon
A lesson for all.
Jon
JFPNCM is offline
post #9 of 9 (permalink) Old 03-12-2016, 06:16 PM Thread Starter
First Name: Al
Right on James. Al
oldrusty is offline
Thin strip ripping jig Cherryville Chuck Jigs and Fixtures 93 01-31-2016 08:04 PM
What a shame they went belly up RainMan 2.0 Lobby 10 05-31-2015 09:38 PM
raised panel doors coupe General Routing 17 03-05-2009 10:17 PM
