Tear out... - Router Forums
 2Likes
  • 2 Post By dvto2
post #1 of 6 (permalink) Old 03-19-2016, 04:50 PM Thread Starter
First Name: David
Default Tear out...
I am using a Whiteside drawer bit on 1/2 Baltic birch for the sides and back and 3/4 maple for the fronts. I have my height and depth pretty well dialed in at .31 inch, and my fit is pretty good, but I'm getting tear out against the face, the side that is against the fence, on my vertical cuts for the sides. Any thoughts or suggestions?
dvto2 is offline
post #2 of 6 (permalink) Old 03-19-2016, 05:06 PM
hawkeye10's Avatar
First Name: Don
Make sure the bit is clean and sharp. Also take very light cuts and a piece of wood to follow your cuts so you will not have chip out.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #3 of 6 (permalink) Old 03-19-2016, 05:19 PM Thread Starter
First Name: David
The tear out isn't following the cut but all along the face. My bit is new.
dvto2 is offline
post #4 of 6 (permalink) Old 03-19-2016, 06:09 PM Thread Starter
First Name: David
So I got better by slowing the cut down but I seem to do better without a backer board as I can control the cut more easily. I still get a little chip out at the end of the cut but it could be hidden by the drawer bottom.
dvto2 is offline
post #5 of 6 (permalink) Old 03-20-2016, 05:37 PM Thread Starter
First Name: David
I tried this again will my Sommerfeld feather board which made it much easier to hold both the workpiece and my backer board steady - this resulted in a clean cut.
BrianS and Roy Drake like this.
dvto2 is offline
post #6 of 6 (permalink) Old 03-22-2016, 06:13 PM Thread Starter
First Name: David
I'm about 50% on getting clean cuts, not so terrible as before, but still some chip out. Very frustrating.
dvto2 is offline
Routing tear out guile1 Table-mounted Routing 12 07-19-2014 10:15 PM
tear out occuring with raised panel cutter dbw Router Bits - Types and Usage 9 04-06-2014 02:48 PM
Best method to band plywood without tear out Slomoe Router Bits - Types and Usage 8 02-26-2011 11:06 AM
a tear out problem loninappleton Table-mounted Routing 3 09-23-2010 08:39 PM
Baltic Birch Tear Out Ross Wigle New Member Introductions 7 01-06-2010 10:16 AM
