no melamine - Router Forums
 14Likes
post #1 of 30 (permalink) Old 04-01-2016, 02:14 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Default no melamine
I'm about to build my mark 3 router table, but i cant find any melamine locally without buying a 10 ft x 4 ft sheet at really stupid money.
I do have some 12 mm (1/2" ) ply that is very flat and smooth.
Anyone tell me why I cant just use ply?
sunnybob is offline
post #2 of 30 (permalink) Old 04-01-2016, 07:19 AM
Many here have used ply for their top. Use two layers for the top, MDF underneath, glued and screwed to the ply. I would also joint some trusses underneath to help keep it flat. Use Baltic Birch if you can find it. Use an aluminum mounting plate. Finish the top and and wax it.
DesertRatTom is online now
post #3 of 30 (permalink) Old 04-01-2016, 07:28 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Tom, youre saying two x 12mm and then mdf? Total thickness must be approaching an inch?
I have a resin plate, but am under backing that with 4mm of aluminium so the plate doesnt sag this time.
Any particular type of wax?
sunnybob is offline
post #4 of 30 (permalink) Old 04-01-2016, 07:34 AM
use it...
if you want to up the smoothness ante use grain filler...
light sanding...
and then begin the sealer/sanding/polishing between coats campaign...
smooth as glass and slick after waxing...
Stick486 is offline
post #5 of 30 (permalink) Old 04-01-2016, 08:00 AM
hawkeye10's Avatar
First Name: Don
Just a suggestion. You could use formica over the ply. It's smooth and would wear way better than melamine.
billyjim and Herb Stoops like this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #6 of 30 (permalink) Old 04-01-2016, 08:08 AM
Johnson's paste wax. Use 3/4 (18mm) for both layers, you get about 1 1/2 inch thickness (36 mm). Heavier and the MDF helps keep it flat. Stick gave you the finishing instructions. I would also add edging of some sort to keep moisture away from the MDF. The weight is substantial with the MDF, which is why I'd add the trusses. Pre drill into the mdf for screws. Put the screws through the trusses by drilling a hole bigger than the screw head to a depth that stops the screw about a quarter inch into the ply. Pre drill MDF always or you will get a bump on top, or even a split. The MDF is for flatness, not structure. That's why I'd add the trusses.
post #7 of 30 (permalink) Old 04-01-2016, 08:23 AM
single layer of 18mm on top of a torsion box frame and a sheet of 5mm on the bottom...
skip the MDF...
http://www.routerforums.com/tools-wo...ld-thread.html
Stick486 is offline
post #8 of 30 (permalink) Old 04-01-2016, 10:12 AM
First Name: Art
Home Depot sells shelving in different lengths and widths.
mgmine is offline
post #9 of 30 (permalink) Old 04-01-2016, 10:14 AM
Bob is in Cyprus...
Stick486 is offline
post #10 of 30 (permalink) Old 04-01-2016, 10:22 AM
I've seen so many members complain over the years that their double laminated table top warped after they glued it together that I've started suspecting that it's the water in the glue migrating into the substrates that might be causing the warping. 2 layers is not needed. I've even seen Pat Warner say so, that the frame underneath is far more important that what you put on it. I built one table, used it for 3 years, then gave it to my son-in-law who's had it for 4 years and it is one layer of 5/8" melamine with 3/8" deep grooves in it for t tracks and it's still dead flat. Despite going from -45 to plus 40 each year. The trick is a good level frame under it. Theo (Joat) has a table that is at least 15 years old that is a single 1/2" ply that is screwed to a 2 x 4 frame that is still dead level he says. Theo didn't use an insert plate he just screwed the router right to the plywood. You lose about 1/8 to 3/16" of depth doing that as opposed to using a plate. The materials have a minor importance in the build. The engineering is what's the most important.
Whiteside Template Bit on Melamine senebraskaee Router Bits - Types and Usage 7 03-17-2014 01:34 PM
Routing Melamine Hardboard over plywood Foos Starting Off 3 09-17-2012 07:44 AM
Working with Melamine rgf Tools and Woodworking 12 08-16-2011 09:59 AM
woodgrain melamine panels denny14 Tools and Woodworking 5 05-13-2009 08:33 AM
Melamine, Formica, Veneers TWheels The Finishing Touch 9 04-23-2007 05:33 PM
