Runout - Router Forums
 2Likes
  • 2 Post By oldrusty
post #1 of 5 (permalink) Old 04-12-2016, 03:10 PM Thread Starter
First Name: Al
Default Runout
I am using a 1/2" cove bit in my table with a hardwood face on the fence to create a zero clearance profile, so there is no dipping towards the bit. I am cutting a profile round the top of a piece of 3/4"x2 1/2"x5" oak. Each one I make, the measurement across the piece between the top edges of the profiles is 1/16" different from one end of the piece to the other. Stand alone, not worth worrying about but when another piece 1/8" smaller all round is mounted on top it's noticeable Solutions anybody ? Oldrusty
oldrusty is offline
post #2 of 5 (permalink) Old 04-12-2016, 03:18 PM
are your pieces square??
are you using a bearing guided bit???
vertical cut or horizontal...
Stick486 is offline
post #3 of 5 (permalink) Old 04-12-2016, 03:26 PM
If the pieces start out square but don't stay that way then you have to be cutting off some of the wood that registers against the fence.
post #4 of 5 (permalink) Old 04-12-2016, 03:54 PM
vchiarelli's Avatar
First Name: Vince
As has been said, I don't think your two long edges are parallel to each other. Make sure your piece is square, then after your rout, measure again and compare.
vchiarelli is offline
post #5 of 5 (permalink) Old 04-12-2016, 05:38 PM Thread Starter
First Name: Al
Sorry folks, forget this thread. " I goofed. " The slightly slanting grain on the piece in question gave an optical illusion that it was not square. In a better light when I placed the next block on top of it I could see that the spacing was even all the way round. Oldrusty.
vchiarelli and jldmor like this.
oldrusty is offline
router runout R Sitter General Routing 4 02-10-2015 10:54 AM
Router guides runout (wobble) problem smilem Tools and Woodworking 9 03-20-2014 01:45 PM
Runout - what is acceptable? rwl7532 Woodturning and Lathes 4 07-28-2012 11:43 PM
wood runout richtad General Routing 6 12-26-2011 07:45 AM
Acceptable runout? presumed_druid General Routing 9 02-09-2005 10:46 PM
