Longer crank handle for Triton - Router Forums
 3Likes
post #1 of 15 (permalink) Old 04-19-2016, 12:34 AM Thread Starter
Default Longer crank handle for Triton
I have built a router table around my Triton MFO01 router, and have started to use it.
I discovered that the crank handle for the built-in lift mechanism isn't long enough to clear the fence when using a tall (long) bit. I discovered the problem when I was routing a T-slot. I used a 1/4" bit to cut the slot, and came back with the T cutter. I did not want to move the fence for obvious reasons.
When the bit requires that the router be lowered very much, the fence interferes with the crank handle rotation.
I tried making a new one from wood, but by the time I drilled out the 7/16" dowel to accept the centering pin on the router body, the wood was so thin that it broke on first use.
Suggestions? Triton does not offer a longer crank that I can fine.
Nickp likes this.
<Chas>
I'll burn that bridge when I come to it
CharlesWebster is offline
post #2 of 15 (permalink) Old 04-19-2016, 01:14 AM
First Name: Ray
A Fellow Woodworker utilizes a socket wrench handle and a long extension holding the allen screw when raising or lowering the router.
Not sure of how the Triton is set up, but it might work.
Ray Newman is offline
post #3 of 15 (permalink) Old 04-19-2016, 01:20 AM
''T'' handle Allen wrench???
Stick486 is offline
post #4 of 15 (permalink) Old 04-19-2016, 01:29 AM
Don't use your drill motor with a hex bit in it. VOE.
Herb Stoops is offline
post #5 of 15 (permalink) Old 04-19-2016, 01:39 AM
agreed... VOE...
Stick486 is offline
post #6 of 15 (permalink) Old 04-19-2016, 06:08 AM
paduke's Avatar
Sounds like a craftsman router I have one that works that way.
For the Triton, 1) remove the crank handle. 2) Drill hole in the end of a block of 5/4 X 5/4X8". 3) Insert Triton crank
Mine hangs from magnetic bar so I also attached a washer. I made from 5/4 so it was grippable
paduke is offline
post #7 of 15 (permalink) Old 04-19-2016, 06:17 AM
katabrontes's Avatar
I would use a length of alloy tube the same as the original and fit a handle onto the top. You could then make it as long as you like.
katabrontes is offline
post #8 of 15 (permalink) Old 04-19-2016, 06:30 AM
add one of these to your Allen shank..
or one of these w/ a ¼'' drive ratchet.......
Stick486 is offline
post #9 of 15 (permalink) Old 04-19-2016, 01:05 PM Thread Starter
The Triton routers use a shaft about 1/8" dia with a pin through it. The stock wrench has a hole in the center with a slot across it.
I think Paduke's suggestion is going to be best. I'll look at taking the crank off the end of the shaft.
Thanks,
<Chas>
post #10 of 15 (permalink) Old 04-20-2016, 02:42 PM Thread Starter
OK, I followed Paduke's suggestion and made this extension for the existing crank:
http://www.routerforums.com/attachme...204969&thumb=1
Thanks to all for your suggestions.
<Chas>
tablesaw rebuild darcyn New Member Introductions 15 10-07-2013 01:34 PM
Router crank routerLiftb5 New Member Introductions 3 09-03-2013 08:13 AM
Triton crank handle position? joel74 Table-mounted Routing 6 04-15-2011 11:01 AM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 02:08 PM
