Incra LS on my MFT - Router Forums
 1Likes
  • 1 Post By suds
post #1 of 5 (permalink) Old 04-19-2016, 08:45 PM Thread Starter
Default Incra LS on my MFT
Only took 7 months to finally get my Incra LS and Incra Clean Sweep all set up between my two MFT tables. I think it will work well for what projects I am contemplating. Can't believe how well the Clean Sweep works just hooked up to my Shop Vac and Dust Deputy.
suds is offline
post #2 of 5 (permalink) Old 04-19-2016, 10:12 PM
furboo's Avatar
First Name: Rob
Sounds great, Bill. I'd like to see photos of your setup.
furboo is offline
post #3 of 5 (permalink) Old 04-19-2016, 11:51 PM Thread Starter
Just got the table oriented to the fence and due to lack of room in my garage I'm literally down to a couple of inches to work with. Been lurking here for years and finally starting to get a setup that will work for me and my neatnick wife.
RainMan 2.0 likes this.
suds is offline
post #4 of 5 (permalink) Old 04-21-2016, 12:17 AM
furboo's Avatar
First Name: Rob
Interesting, Bill. In the picture, I assume your other MFT is to the left of the router table. How do you like having the fence on the MFT?
I guess I also prefer to have the miter track parallel to the fence.
furboo is offline
post #5 of 5 (permalink) Old 04-21-2016, 08:47 AM Thread Starter
Since I just got this set up I'm not completely convinced that the miter track alignment will be what I want. If not then I'm going to have to remove about 6" off the back of the table and turn it so the track is parallel to the fence. Yes, the other MFT is off to the left. I do like the fence on the MFT as I know the fence is square to the table and so far everything has aligned to the router table.
I'm sure there will be some discoveries/adjustments but it seems to be a good start.
suds is offline
INCRA Engineers Quality Tools, but... almost there Tools and Woodworking 14 01-07-2013 11:23 PM
Router Lifts: Incra SWHD vs. Incra PRL-V2 Gato9 Tool Reviews 3 09-23-2011 06:14 PM
Router Lifts: Incra SWHD vs. Incra PRL-V2 Gato9 Table-mounted Routing 0 09-23-2011 09:17 AM
Router Lifts: Incra SWHD vs. Incra PRL-V2 Gato9 General Routing 0 09-23-2011 09:14 AM
Festool MFT - Incra Ron Nainby Jigs and Fixtures 5 03-14-2011 02:07 PM
