Angle dovetails with incra?? - Router Forums
 4Likes
post #1 of 20 (permalink) Old 05-12-2016, 10:13 PM Thread Starter
Default Angle dovetails with incra??
Hi All
Has anyone been able to do an angled dovetail using an incra fence...Pictures speak volumes
Thanks in advance
G Vavra
kimosawboy is offline
post #2 of 20 (permalink) Old 05-12-2016, 11:20 PM
Hello G and welcome to the forums...
Stick486 is offline
post #3 of 20 (permalink) Old 05-13-2016, 07:16 AM
kp91's Avatar
First Name: Doug
It is pretty straightforward on the Keller Jig, that is all I have ever cut an angled joint with.
I can't find anything online for the Incra. The hard part i see for the Incra is holding the stock to the fence at the correct angles. You could try making sloped auxiliary fences to support your pieces.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #4 of 20 (permalink) Old 05-13-2016, 08:11 AM
First Name: Jerry
Talk to the people at Incra. 1 888 804 6272
Jerry Bowen is offline
post #5 of 20 (permalink) Old 05-13-2016, 08:26 AM
Nickp's Avatar
First Name: Nick
Can someone post a picture of an "angled dovetail"...apparently my 3D spatial thinking module is on the fritz today (all technical jargon). I keep getting this image in my mind of a piece of wood moving it's way through an invisible table top at an angle...sorta holographic...spinning around while somebody dressed in a Merlin suit is making waving gestures with his hands...
Sorry...must be something in the coffee...
Are you trying to join two pieces at greater or less than 90 using dovetails or is one of the pieces at an angle to the other (sorta parallelogram-ish)...?
@kp91 Can you post one of what you did with the Keller...?
Nick
Nickp is online now
post #6 of 20 (permalink) Old 05-13-2016, 08:47 AM
Nickp's Avatar
First Name: Nick
Originally Posted by schnewj View Post
Let's hope that while you're standing on that rock, in the middle of the storm and the lightning strikes and you have that "Ah-ha" moment.
Try this...
https://www.youtube.com/watch?featur...&v=kk3tV_WvKlU
"Ah-ha"....and with a puff of smoke, Merlin disappears...gonna check the coffee though...thanks...
Nick
Nickp is online now
post #7 of 20 (permalink) Old 05-13-2016, 08:53 AM
schnewj's Avatar
No time for coffee...no food or drinks at the computer...get to work!
schnewj is offline
post #8 of 20 (permalink) Old 05-13-2016, 11:18 AM
kp91's Avatar
First Name: Doug
this demo is pretty good on doing the machine angle dovetails. Part one is 'normal corners', part 2 and 3 are compound corners. I wish I had this video years ago. My project was no where near as complex, I did not use a compound angle. It was a simple magazine pocket on a side table, so the ends were vertical and the piece came out as an angle.
the attached instruction page shows the wedge needed to be used when doing compound cuts pretty clearly.
Name:	keller angle instructions.JPG
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #9 of 20 (permalink) Old 05-13-2016, 02:27 PM
DonkeyHody's Avatar
First Name: Andy
I made a bunch of serving trays that way about 10 years ago. It's not for the faint of heart. Lots of ways to screw up and I found most of them.
Remember that each edge to be joined must approach the bit at 90 degrees relative TO THAT EDGE. The piece with tails must be attached to the slider at an angle so the angled end sits flat on the table (see image 249).
The piece with half-blind sockets needs a tapering jig to slide along with it against the fence. This jig is represented in image 252 by the red sandpaper. The jig really needs to be slightly longer than the workpiece and the jig needs a hook on the end to carry the workpiece along with it.
Now that I have a Leigh DR4R, I wouldn't use the Incra to make these joints, but if it's what you have . . . .
kp91, Nickp, Stick486 and 1 others like this.
DonkeyHody is offline
post #10 of 20 (permalink) Old 05-13-2016, 03:34 PM
no sharing???
Stick486 is offline
Help with Incra Jig through Dovetails Duncanrouter Table-mounted Routing 30 02-27-2015 10:40 AM
dado blade for spline joining sjonesphoto Tools and Woodworking 34 03-11-2014 11:11 AM
Incra Dovetails - cuts going with the bit Steve-H Table-mounted Routing 8 02-01-2012 10:18 AM
incra jig right angle bruce thom Jigs and Fixtures 20 06-29-2009 02:01 PM
Incra jig and rabbeted half blind dovetails S Bolton Jigs and Fixtures 10 08-24-2007 01:06 PM
