Whats required - Router Forums
 2Likes
post #1 of 22 (permalink) Old 05-14-2016, 11:51 AM Thread Starter
OldSteve's Avatar
First Name: Steve
Default Whats required
Hi,
I have some 1-7/8 inch thick Walnut that I would like to shape with a long straight patten/template bit with a bearing using a hardboard template. All I have now is a 1/4" 1 HP router & table that I know will not work. Have you any suggestions as to size of router or bits that might do this or is it even possible?
OldSteve is offline
post #2 of 22 (permalink) Old 05-14-2016, 12:21 PM
Welcome to the forum, Steve. They like that open ended kind of question here. There will be a lot of good advice headed your way very soon.
Herb Stoops is online now
post #3 of 22 (permalink) Old 05-14-2016, 01:07 PM
Welcome Steve. Your router would probably do it if you can find a bit long enough in 1/4" and you take a light pass. A 2 hp or about 12 amp router would be better. Something like a Bosch 1617.
post #4 of 22 (permalink) Old 05-14-2016, 01:08 PM
First Name: Clay
Welcome to the forum. What you are asking should work assuming you cut the piece to very close to finish size and take light passes. I have not looked to see if you can find a bit that long but once you cut so far you can remove the pattern and use the work piece as the pattern.
fire65 is offline
post #5 of 22 (permalink) Old 05-14-2016, 01:56 PM
kp91's Avatar
First Name: Doug
Exactly. You are going to have to take MANY passes to get down to the depth you are looking for.
Practice a few times in an offcut to see what kind of feed rate works best.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #6 of 22 (permalink) Old 05-14-2016, 01:56 PM
paduke's Avatar
. . . if you can find a bit long enough in 1/4" and you take a light pass. A 2 hp or about 12 amp router would be better. Something like a Bosch 1617.
That seems to be a big if. Searched for one and got cross eyed looking for 1/4" shank Nada for me 2" cutting length seems a bit much for a 1/4" shank Can anyone find one. Maybe you can use a 1/4" straight bit long enough and use a bushing along the template. But I can't find a bit long enough
paduke is offline
post #7 of 22 (permalink) Old 05-14-2016, 05:47 PM
couldn't find one either...
recommend a Bosch 1617 and a ˝''shank...
post #8 of 22 (permalink) Old 05-14-2016, 05:56 PM
vchiarelli's Avatar
First Name: Vince
Can you use two templates, one on each side of your piece and route from both sides - that will reduce the distance to 1/2 of the depth each way. The only issue is getting your templates lined up.
Semipro likes this.
vchiarelli is offline
post #9 of 22 (permalink) Old 05-14-2016, 06:12 PM
I would suspect that they can't be found either. Too much flex at that length. You have to be careful with 1/2" bits that long.
post #10 of 22 (permalink) Old 05-14-2016, 06:19 PM
Semipro's Avatar
First Name: John_*
Welcome to the router forum.
find yourself a 1/4" flush cut straight bit with top and bottom bea straight bed with top and bottom bearing and cut from both sides,
Freud 50-501 Top & Bottom Bearing Flush Trim Bits 1/4-Inch shank Features Freuds TiCo? Hi-Density Carbide with Titanium
Thank You John
Semipro is online now
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
CNC Router 3d carving - cutters required RiffRaff CNC Routing 8 05-19-2014 06:24 AM
Are collet extenders no longer required? harrysin Lobby 23 05-12-2014 06:32 AM
Elu 96e type 2 wiring help required smudgers2 New Member Introductions 6 03-19-2013 02:39 PM
SMS Transitional Planes Information Required IanStagg Tools and Woodworking 1 02-27-2012 12:14 AM
