TRA001 height adjustment changes when locked - Router Forums
 1Likes
  • 1 Post By Mike
post #1 of 9 (permalink) Old 05-17-2016, 02:10 PM Thread Starter
Default TRA001 height adjustment changes when locked
Hi,
I have a table mounted TRA001 that I'm having a small issue with. After I set the bit height and lock it, I can see the adjustment knob start to slowly spin when I turn on the router. The bit height doesn't move since I have the router height locked. However, if on my test cut I found that I need to adjust the height slightly, when I unlock the router the router drops because the adjustment has turned. Has anyone else experienced this? I'm not sure what to do about it.
Thanks,
TakingAHike is offline
post #2 of 9 (permalink) Old 05-17-2016, 03:25 PM
Hey, Mike; welcome!
(Sorry, can't help with your question.)
DaninVan is offline
post #3 of 9 (permalink) Old 05-17-2016, 03:51 PM Thread Starter
Thanks for the welcome Dan! I'm sure someone will have some insight for me.
post #4 of 9 (permalink) Old 05-17-2016, 03:54 PM
paduke's Avatar
Yes it happens. There is slap in the worm gear. It has happened to me. It does not happen it seems when I make the final raising the router instead of lowering. it. It might help if you retighten the height screw before unlocking the router In older models the worm gear was nylon. If that is the case with your model They used to ship you a free replacement. Hope that helps
paduke is offline
post #5 of 9 (permalink) Old 05-17-2016, 03:57 PM
I am curious though, Mike. Did you query the manufacture's Customer Service dept?
I suppose you could try turning the knob until the backlash is removed, before you unlock the body. Short term might work(?)...
DaninVan is offline
post #6 of 9 (permalink) Old 05-17-2016, 03:58 PM
Ha! Bill beat me to it.
DaninVan is offline
post #7 of 9 (permalink) Old 05-17-2016, 04:02 PM
On all routers/lifts it is best to make the final height adjustment going up not down.
bcfunburst likes this.
post #8 of 9 (permalink) Old 05-17-2016, 04:28 PM Thread Starter
Thanks for the input guys. I'll see if it helps to make the final adjustment going up. I didn't realize that was the best way. It won't turn on me if I lock it and then turn the crank to preload the gear. The only problem with that is I need to keep track of how much I turn it so if I need to go back and make a small adjustment, I get back to my initial setpoint. I'll try giving Triton a call as well to see what they say.
Thanks!
post #9 of 9 (permalink) Old 05-18-2016, 12:37 PM
bcfunburst's Avatar
First Name: Reg
I solved my similar problem by using a spare scissor jack from a car to raise and lower my TRA001. Works great for a router lift. Price was right too.
"Even bad decisions make good stories"
<bcfunburst>
bcfunburst is offline
Newbie question about above table height adjustment patdavid Table-mounted Routing 6 02-13-2013 04:46 AM
Bosch 1617EVSPK height adjustment issue jwilwerd New Member Introductions 3 12-10-2012 04:09 PM
Bosch height adjustment rgardner41 Table-mounted Routing 6 10-21-2012 07:23 PM
Need a router w/ accurate and easy height adjustment in table use. WoodTroll Table-mounted Routing 26 04-10-2011 12:11 PM
Craftsman 17543 Combo Fixed Base Height Adjustment Gator95 General Routing 14 11-29-2008 03:30 PM
