Routing a Spindle - Router Forums
post #1 of 7 (permalink) Old 06-19-2016, 06:59 AM Thread Starter
Default Routing a Spindle
Hi Guys ,
Its been a while since Ive posted anything.I have a ?.
I a flutemaker.I bore a 7/8" hole in square blanks anywhere from 1 1/2" to 2" square.These are mostly around 30" long.After boring them I turn down the outside dia to around 1 1/4".I like to have a taper on these sometimes ...like turning them down from 1 1/4" on one end to maybe 1 1/8" on the other end.The taper is not absolutely necessary.(All this is flexible). Anyhow I have read in the past where some makers will use a router on a table to more consistently make them round...sort of like making a dowel.I have never quite understand the process.I am not sure on how to set this up, what bit to use etc. Any help will be appreciated.. ( I never really understood the making of a dowel on the router table...That might would help) Thanks a bunch in advance.
Flutemaker is offline
post #2 of 7 (permalink) Old 06-19-2016, 07:23 AM
check out this thread https://www.google.com/url?q=http://...Kp38U4H46glkXQ for a really outstanding thread on building a lathe to make pool cues using a router as I'm sure that the same process, other than the center hole, could be used for making your flutes.
tomp913 is offline
post #3 of 7 (permalink) Old 06-19-2016, 07:36 AM
Gene Howe's Avatar
First Name: Gene
Use a bull nose bit as in this video. https://m.youtube.com/?hl=en-GB&gl=G...?v=5DUOHSUbkf8
You can find a 1-14 bit on line.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #4 of 7 (permalink) Old 06-19-2016, 08:32 AM
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Hi, Mike.
I am looking for the same advices. Thank you for posting my needs.
We, woodworkers are everywhere!!!
papasombre is offline
post #5 of 7 (permalink) Old 06-19-2016, 04:24 PM Thread Starter
Oh my that is some interesting stuff..Id love to build one of those router lathes..Hmmmm not enough hrs in the day!! Thanks everybody!!
post #6 of 7 (permalink) Old 06-19-2016, 09:47 PM
I use a 1/4 or 1/2 round cutting bit and make a square piece the size of the finished dowel . On the router table take the square piece and start the cut 2" or so from the end and cut to 2' or so from the other end. Rotate and make another cut, and so on til it is round all way around then cut off the square ends.
Herb Stoops is online now
post #7 of 7 (permalink) Old 06-19-2016, 11:03 PM
JOAT's Avatar
First Name: Theo
Ah well, I guess I'll always do things different. Me, I'd just make a long rectangular box, with centers on each end to hold the work, and a electric drill to spin it. I'd have the top of the box just high enough to be level with just how much I want to take the stock down, and a taper would be just as easy. And the box would be made so a power hand belt sander, or planer, would set on each side, then just slide it along. Yep, it will work, not actually done it this way, but have used a power hand planer on a lathe, to make a couple of carving mallets. That was holding it by hand, and boy, did I ever have to be careful, because it really, really, removed stock FAST, still got the mallets too. I figure this would be a whole lot less hassle than making a router lathe. But, I suppose you could use a router this way too, but probably have to have a little 'wiggle' room to shift it back and forth. In fact, some time later, I'll be making a barrel spinner somewhat similar to this, belt sander only tho.
And remember, just because this is the way I would do it, doesn't mean you should do it. So, if you do it like this, and get hurt, don't blame me.
JOAT is online now
The Difference Between Water-cooling Spindle and Air-cooling Spindle Mini CNC Router china-cncrouter CNC Routing 31 06-14-2015 09:24 AM
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
old person new to routing in wood sailer670 New Member Introductions 12 12-13-2014 07:31 PM
Use of template Guides cutter79 Guide Bushings and Templates 6 08-21-2013 03:18 AM
CNC routing as first routing experience ianthehenry CNC Routing 23 04-25-2012 04:24 AM
