Right angle guide - Router Forums
 11Likes
post #1 of 19 (permalink) Old 08-24-2016, 10:33 AM Thread Starter
Knothead47's Avatar
Question Right angle guide
I have a Kreg bench top router table. I have a part (can't remember the name!) that slides in the t-track. It is drilled and tapped in several places. Question- what is the best way to build it to make 90 degree passes on the table? Can it be adapted in some way for 45 degrees also? Thanks.
Table works great for long passes but I need something for the short passes over the router.
Have a Groz precision square if that helps.
John T.
Life is like water-skiing; if you slow down, you go down.
Knothead47 is offline
post #2 of 19 (permalink) Old 08-24-2016, 04:52 PM
hawkeye10's Avatar
First Name: Don
Could you explain exactly what you are trying to do. I think it would help answer your question better.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #3 of 19 (permalink) Old 08-24-2016, 04:56 PM
It sounds to me you're talking about a right angle sled but a square push block against your fence is easier. If you watch Marc Sommerfeld's you tube videos you'll see him using a push block for doing the profile on the ends of cabinet door rails.
post #4 of 19 (permalink) Old 08-24-2016, 07:31 PM
paduke's Avatar
Originally Posted by Knothead47 View Post
a part (can't remember the name!) that slides in the t-track. It is drilled and tapped in several places..
Sounds like a piece of milled bar stock probably 1/4"X3/4" with several tapped holes probably for a miter gauge with parts removed
paduke is offline
post #5 of 19 (permalink) Old 08-24-2016, 07:44 PM
First Name: Earl
If it looks like the picture below, it is called a miter gauge. If so, it is designed specifically to push stock at an angle. Also comes as a "system" as shown in the second picture, but a hardwood or mdf scrap could serve as the fence as well--so long as it is straight.
earl
Herb Stoops likes this.
greenacres2 is offline
post #6 of 19 (permalink) Old 10-21-2016, 03:09 PM Thread Starter
Knothead47's Avatar
Question
Finally got a round tuit. You can get anything on the Internet. Yes, it is basically a miter gauge that I'm wanting to build. I got the part that goes in the T-track at Woodcraft. Just need some help in the basic design or ideas. Many thanks. Have a project for SWMBO- building a rack for her necklaces using various drawer knobs. With all the jewelry he has now, I figure a 4X8 baltic birch panel will work.
John T.
post #7 of 19 (permalink) Old 10-21-2016, 03:18 PM
vindaloo's Avatar
First Name: Angie
Have a look at this one. I have the metal runner ready and the rotating part, but it is also a round tuit, and I haven't got there yet
When everything around you is going to pot, get out in the workshop.
vindaloo is offline
post #8 of 19 (permalink) Old 10-21-2016, 03:31 PM Thread Starter
Knothead47's Avatar
vindaloo, thanks for the great video! Well done- good sound, no blocking one's view with fingers or hands, clear step-by-step visuals. I was pondering how he cut the groove for the base to pivot. Sheer genius. I would have fussed and fumed while trying to figure it out myself. Gives me a great starting point.
paduke and Herb Stoops like this.
John T.
post #9 of 19 (permalink) Old 10-21-2016, 05:20 PM
https://www.youtube.com/watch?v=VR4jAdiA3tc
Sure like that Video, Angie, Short and to the point, not long winded like a lot are. I got some good ideas from it too. Thanks for posting.
Herb Stoops is offline
post #10 of 19 (permalink) Old 10-21-2016, 07:18 PM
RainMan 2.0's Avatar
Great job on the video
I was thinking it would be cool too add a piece that drops down and has a bolt in it to calibrate it to zero as a stop
Ok ,I never insulate
RainMan 2.0 is online now
Craftsman-Bosch router guide WillMatney Jigs and Fixtures 21 07-26-2015 06:56 PM
Triton guide bushes...... jw2170 Guide Bushings and Templates 17 05-13-2015 01:15 AM
dado blade for spline joining sjonesphoto Tools and Woodworking 34 03-11-2014 12:11 PM
Freud Edge Guide Mystery Chappmann Jigs and Fixtures 4 12-26-2011 02:36 PM
Router template inlay V Garry General Routing 7 12-27-2008 07:49 PM
