You can use either. I generally prefer the 12 half inch shank because the collet has more surface area to hold the bit in place. The larger shank, however, still has to get small enough to accommodate the narrow end of the cutter, which will be fairly similar to the quarter inch shank, so it's probably not much different in terms of cutter strength. Note that the bearing on both is similar in size.
