1 - 5 of 5 Posts
I'm sure this has been covered somewhere already but... I have the Bosch colt. I'm having doubts that the correct collet came with my "factory reconditioned" unit.
Should the router bit slide easily all the way though the collet?
Welcome to the forum, Gary.
What brand of bits are you using? I find more inconsistency with the bits than with the collets. [especially the cheaper brands] Can you measure the bit shank?
Try the shaft of a 1/4" drill bit to see if that fits.
after the collet is opened past it's self releasing feature...
Gary
Most palm or trim routers have a 1.4" collet. The bits should slide in and out fairly free as long as the collet is opened. Once you tighten the collet, it should hold the bit tight. I like the way James said to check it. Drill bits are made to a tight tolerance and this would be an excellent test.
That's one of the things with Colt,if goes pass the point the collet will brake in to 2 parts..and will need to be replace..and yes the bit should fit all the way into the collet ,,to the cutters on the bit if bigger than the 1/4" shank.
1 - 5 of 5 Posts
