1 - 14 of 14 Posts
Colleagues: have an older Sears 10, ,72 tooth with 3 expansion slots, carbide blade that was re-sharpened about 10 years ago. Put it away and never cut with it the re-sharpening.
I can not recall if it was for a table saw or a radial arms saw. Had a radial arm and sold in the early 1980's to buy a table saw. And I recall having carbide blades for both.
How can I determine of the blade is for a table or radial arm? Fellow Woodworkers told me to measure the tooth angles. One said the blade angle makes no difference.
But how do I get an accurate reading off the outer edge and a tooth (or teeth)?
Ray, you are smarter than I am,that is a good question. I would just put it on my table saw and if it cut OK, it would be a TS blade.
One reason the RA saw blade was sharpened at a different angle was to decrease the blade wanting to climb cut since a RA saw is pulled ,or fed the opposite of the way a blade should be turning to make a cut. But you know that. I might be wrong,once was, but it shouldn't make that much difference on a TS.
here ya go Ray...
I'm surprised you aren't saving these PDF's...
Reactions: MYB506
For a miter saw or radial arm the angle should be zero or negative. The are fine finish blades that have a 10 or 15* hook for use on the TS that have that many teeth and more.
After SSK, Sticks School of Knowledge, I am pleased to announce that he taught me where to find them. And there is a ton of those little buggers I've been looking for a long time.
Charles after reading through the pdf, it seems as though the negative angle blade for the RA saw will cut OK on the TS only you might experience a slower feed rate than with a regular TS blade.
Herb I did try one of my 60 tooth, -6* hook on the TS to test cut a small piece of melamine and it did work very well. I thought there might be a tendency for the piece to lift up with the negative hook but I didn't experience that. However, since I only tried it once and in a very limited test I am hesitant to recommend it to anyone yet.
Reactions: DaninVan
1 - 14 of 14 Posts
