Hi, Dodd: Welcome to the forum. Yes, you can do the task with a router and a template. You will also need the proper bits to do it with. A template could be made
by hand as you now make the knives. I would use either a hard wood or some decent plywood about 1/2" thick. the template should be sanded so the edges are exactly what you want, because any imperfections will show in the finished product. Cut blank material for the knives on a band saw or a jig saw leaving about 1/16th" around the perimiter. Use either a bit with the bearing above the cutting edge of the bit,
or use a bit with the bearing below the cutting edges. Two sided carpet tape can be used to attach the blank to your template and depending on which bit you use either the blank would be above or below your template. A starting pin must be used to safely get the blank to the bearing surface, it gives you a point to start the cutting
once you start the cut you can then more away from the pin and direct the material into the cutting edges of the bit. I would suggest you get a book on basic routing be fore attempting to do this, so that you can see how it is done.
Hope this helps, Woodnut65
