Can anyone recommend a 5-axis CNC router that can carve complex 3D wood sculptures? It needs to be making ca. 25''x25'' objects and on the Z-axis about 5'' as a minimum. It does not need to be fast nor does it need to carve many objects. Precision should be around 0.01mm. The attached pic is the final sculpture (a piano leg) that would need to be assembled from horizontally sliced sections of the total leg (ca. 5'' in height).
Since it's for less than 10 legs the router should not be above 10K.
Alternatively, if anyone knows of a reasonable CNC firm that can make the product for me, that would be fine, too.
Thank you!
Thank you!
