1 - 1 of 1 Posts
Discussion Starter #1
1. You will be wise to match the room with your choice of flooring, whether hardwood or otherwise. For example, do not try to put hardwood flooring in a bathroom, due to the high levels of moisture a bathroom receives.
2. Different areas of the house demand different types of wood. For example, wood floors that have very light or very dark finishes typically do not fare well in the kitchen.
3. Choose a hardwood flooring that has an appropriate finish to match your lifestyle. A sitting room that is seldom used will let you get away with a lighter finish. However a hallway or living room will get continual traffic and requires a choice that offers a tougher finish that can stand up to a lot of wear and tear.
4. Consider installation - doing it yourself or having a professional installer do it for you? Many people successfully install their own flooring, but only after they have done their homework. It is often easer to hire a professional, but do you due diligence when selecting a hardwood flooring installer. You will want to be absolutely sure that it will be installed correctly.
5. Choosing the color and style of the floor can be the fun part. Choose a hardwood that fits your personal taste and your lifestyle. The comparatively high cost of the flooring and installation demands choosing a wood that will not go out of style quickly.
1 - 1 of 1 Posts
