I don't use Carbide Create but looks like the diameter needs changed to 0.125 but the rest of the important parameters for the bit look okay. Have you tried an air cut using it to see if it looks like it would work properly?
number | vendor | model | URL | name | type | diameter | cornerradius | flutelength | shaftdiameter | angle | numflutes | stickout | coating | metric | notes | machine | material | plungerate | feedrate | rpm | depth | cutpower | finishallowance | 3dstepover | 3dfeedrate | 3drpm |
503 | Carbide3d | 90 Dia Drag | ![]() MC Etcher - Diamond Drag BitMC Etcher is our new 90 and 120-degree diamond drag bit. It is perfect for fine line engraving on composites, metals, and glass. MC Etcher is spring-loaded which makes it easy to engrave on uneven surfaces. The spring, which sits under the tip, allows it to adjust as it moves over the surface of...
![]() | 90D Diamond Drag | Dia Drag | 0.25 | | | 0.25 | 90 | | | | 0 | | Shapeoko | Brass | 15 | 45 | 1 | 0.02 | | | | | |
