Make sure both surfaces a very clean, I have not usually found it necessary to thin solvent based contact cement. after appling cement to both surfaces allow it to almost dry (tack-up) put something between the surfaces to keep them apart -dowels.sticks etc.put
the plastic laminate on the dowels and then remove the dowels(one at a time). You will definately need a heavy duty roller to work the laminate. It sounds more complicated than it is.
Regards
Jerry
Regards
Jerry
