I wanted a little Halloween sign for the candy bowl we leave at the gate on Halloween. Our drive is too long and dark for trick or treaters and we have never had a problem just leaving a bowl with candy and using the honor system. Most of the little ones have parental escorts so it isn’t a problem.
I thought a reminder sign would be a good idea, as well as fun, but I didn’t want to waste any stock that could be used for real projects. So it was time to use the black foam-core material that came as packing with an order of HDU sign material.
Trying to hand letter a sign wasn’t in the cards and since the material is black I couldn’t easily transfer my design to it for painting. Then I had one of those “Aha” moments. Time to cheat. I quickly set up a file in V Carve and then cut just the outlines of the design into the surface of the material with a 7.5º V bit and a .05” depth of cut. Then it was an easy job of cutting the shape on the bandsaw and painting inside the carved lines. Total time including carving, cutting, and painting was about 45 minutes and gave me a nice rustic looking painted sign.
