I suggested that. See response above.One suggestion I would tell you is to install a 1/2’’ or 1/4’’ o-ring in the bottom of your collets. You leave the o-ring in the collet until you change sizes of you bit shanks. You will never have to mark your bits with a line or pull your bit up again. It becomes a solution to a problem you will not have to worry about again.
