Harry,I intended to send you a email re the following, but thought it better via the forum as it may help others. How critical are the dimensions of this project?
I have a block of laminated pine 8 and1/4 by 8 inches by 2 and 3/8 thick. My largest brass guide bush is 35mm (1 and 3/8 inch) and a 12mm (1/2inch ) straight cutter.I have mdf for the template at 12 mill (1/2 inch) or 4 mm (1/4 inch)
Can I utilize the above for this project? My cam box is 2inches in height, Do I machine the workpiece back to say...1 and 1/4 inch to take the half inch template, or 1 3/4 inches to take the 1/4 inch? If this is unacceptable can I use the cam board without the box...use double sided tape for the template and secure the workpiece with the cams?
I also realize you cant answer each individuals problems but maybe you can shed some light on these questions.
Regards.........AL
Al, there is nothing critical in this project, it was aimed at beginners to show them alternate methods of using the router. I'll try to answer your questions as they appear.
2 3/8" is far too thick for this project, even using a straight cutter you would be struggling to reach a 2" cut, especially if you intended to use skis, which I didn't for the inside. In any case, do you really have that much spare change for such a deep coin tray? By making the tray about 5" dia., it ensured that the router could sit directly on the template for plunge routing the inside, bigger than that and the skis would be required.
The 1 3/8" guide would be fine and if used with the 1/2" cutter would give an offset of 7/16" meaning that the hole in the template would be 7/8" bigger than the inside of the dish, in other words if the dish internal diameter is 5", then the hole in the template will be 5 7/8". By using the same guide and cutter, the wall thickness will be 7/16".
The 1/2" MDF is better than 1/4" and is what I used, simply because it was handy, but I normally use 3/8".
As for securing the work piece, it really doesn't matter how you do it, I personally find the method shown to be the simplest. I do have a selection of boxes/frames using various methods of securing the wood and vary these on different projects to show members different methods that can be used, but do bear in mind Al, the forum motto: KISS, keep it super simple.
Finally, let me assure everyone that metric is far, far easier to calculate offsets than Imperial and if members started to tell manufactures and retailers that they WANT metric guides and cutters, you will eventually get them and no doubt thank me for pushing this subject, also the fact that fixed base routers are for tradies in the building industry, the rest of the world, that is other than the USA use PLUNGE routers the norm. I hope that I've answered your questions Al, if not, keep asking, there will almost certainly be others in the same position.
