add lock collar and bearing, is it safe?
3012 Views 8 Replies 5 Participants Last post by  Stick486
I see that they are sold but wondering about the safety of adding a lock collar and bearing to a 1/2 spiral bit for pattern finishing. I also would be worried about having that much less of the shaft to put into the collet. The spiral bits sold with bearings are mucho $$$. Thanks, Tom
1 - 9 of 9 Posts
Use a template guide bushing
Lots of info on this forum and videos on YouTube
Reactions: 3
how much shaft are you inserting into the collet now???
adding a bearing is safe as long as all the components fit...
why not use a helix bit???
https://www.freudtools.com/search?h=1
they give/do a very clean top edge and w/ the pattern clamped onto the bottom you get a clean bottom edge also...
the pattern behaves as a backer board...
I'm with Doug on this...a 1/2" ID bearing will give you 3/4" OD on the bearing surface. Depending on what you're doing with it, it could require you to use a big bit.
Guide bushings will allow you to use a smaller diameter bit.
still, pattern and finished product will be off set requiting a smaller pattern...
use the Helix and existing pattern...
Generally when a bearing is on a straight bit it matches the O.D. of the bit. Yours wouldn't do that so it depends on what you are doing whether that is workable or not.
I guess I don't know much about Helix bits. I'll have to learn. Thanks
https://m.youtube.com/watch?v=pnqP3qVjCLY
Also really good video on bushings that will make me reconsider my options. Thanks
let's get you started on the how to's..
we put together a touch of education over here at this link...
Reactions: 2
1 - 9 of 9 Posts
