Setting up the new table saw. Adjusting the fence for parallel to the table/miter slots. Instructions are clear enough on HOW to do it (loosen this screw and then adjust with that screw), but are silent on just how close to parallel the fence should be.
Out of the box, it was slightly closer on the outfeed side. I've adjusted it to where it is about 0.010" further away on the outfeed side. My rationale is that it should be either perfectly parallel or slightly wider on the outfeed side to lessen the tendancy to bind.
My method is to secure precision parallels against the miter slot on the near and far side of the table, by expanding adjustable parallels in the slot between the precision parallel and the opposite side of the slot. The precision parallels do not move at all. Then use feeler gauges to measure how far away the fence is from each parallel. This is a jobsite model table saw, so its fence is not nearly as secure as on larger saws, so there is some give and take when it comes to consistency of clamping/position. Taking that into consideration, I loosen and re-tightened the fence several times, resulting in slightly different positions each time and consequently, different thicknesses of feeler gauges come in to play, but the difference is consistently about 0.010" between the two positions.
Is this a suitable method and what differential should there be, if any?
Thanks,
Rick
Thanks,
Rick
