1 - 8 of 8 Posts
Discussion Starter #1
I'm just looking for some advice for this as I just finished my first one and tried routing it. I'm quite pleased with the result but in a few patches despite a lot of filing and sanding I still had some minor undulations, not really cut marks left over from the bandsaw but where theres more of a bump where the should be a consitent curve.
Can anyone suggest what I can do to get rid of this? I'm using plywood which I cut on a bandsaw, then gentle file, then sanded it with paper by hand or just wrapped round a cylinder (I dont own any power sander machines).
Maybe I should switch to MDF? Maybe a rougher grit of paper to start?
Hi Shesu
Just use a coarser grit. If needs be on a template for one time use you can repair with 2-pack car body filler and resand, or even use a gash template to make a new one in fresh material (with a template bit rather than a guide bush/bit), but reworking only the bad area(s)
Regards
Phil
Discussion Starter #3
Thanks I'll give that a go and see how it works =). Might try the car body filler thingy too.
If you are having problems on a curve try to find a can the same size or smaller and wrap your sand paper around it.
"I'm just looking for some advice for"
The thing here is to exploit the router itself. Given the right setup it and you, you can produce a templet that needs no hand work. Moreover, the cardinal rule of machining: whence produced, do not mess with a machined surface.
I agree with all of the above.
I like to use 3/8 or 1/2 inch MDF for my templates, because it's tough, void free, and most importantly, cheap. I have long been a champion of using 'bondo' for repairing damaged patterns, but recommend copying a pattern after it is repaired.
A handy sander for gracefull curves is a piece of formica or flexible plastic with sandpaper glued to it. It is fairly flexible, and prevents you from taking too much off in any one spot.
If it's for one-time use, wait, when does that ever happen?
All of my templates are two pieces of 1/2" plywood glued together. I cut the template in one piece, make it as perfect as I can, then glue that to another piece of 1/2" plywood, and when the glue sets then rout it out. I like to tack my templates down with 1 1/4" or so nails, so drill nail pilot holes. Then tack the 1" template to a piece to be routed. Rout. Look at the result. If it is not 'perfect' then I go over the template/master, and try again. At times I even remake my template, starting with the piece routed from the first. I have done this as often as three times, until I get it just as I want it. I do some figure banks that call for some quite precise pieces. I like the 1" thickness, because I find it a lot easier to handle and control when routing.
At times I have even been known to cut out a piece of a template, glue a new piece in, then shape that. But when I do that, usually I just rout out a piece for a new template, and go from there. Oh yes, I also write any need to know info on the template/master (I prefer to call them masters), and sometimes even the word MASTER; this prevents me from accidently using a master in a piece, then having to start all over again - been there, done that.
1 - 8 of 8 Posts
