Advice on CNC production.
848 views 3 replies 4 participants last post by  old55
Good day.
I have a design that I need produced but I am clueless to the production side using CNC. I need to sort out how to produce this at high volume. I may begin with about 50 to 100 pieces. however, if the design proves itself for further production, I may need several thousand.
Firstly, I have no idea what CNC process to use - 4-axis / 5-axis? I designed the wood piece in Fusion 360.
Also, I should add that I am wanting to use solid wood - preferable birch - at 6.5mm thick.
As you can from the layout, there is the general shape - but with the additional drill holes that need to be accurate.
Would love some advice!
Jon
Welcome to the forum.
Reactions: JONEK
