Hi Guys,
Well I just got my new Incra 25" Range LS Super System with 27" x 43" Router Table and Stand on Friday for Father's Day.
I have a new Incra Mast-R-Lift II Router Lift to go into my new Incra Router Table System. I'll be using my Bosch 1617EVS Router in my lift.
I've done a initial assembly of the metal and Aluminum Incra stand for the table system, but I haven't as yet mounted the Incra Table top to the stand. Instructions says to use the (12) #10 x 3/4" Phillips Pan Head screws to fasten the table top to the metal stand.
I really don't like the idea of using these wood screws to fasten my table top to the stand. So my question is: Could I use some #10-24 Brass inserts and some #10-24 x 3/4" long bolts to fasten the table top to the metal stand?
My thoughts are to lay the table top on the floor upside down, and carefully position the metal frame on it, then use a transfer punch to mark the 9 hole locations. Then use a new Brad point bit with a depth stop collar on it to bore clean holes through the melamine into the MDF core, then insert Brass #10-24 inserts, then use #10-24 x 3/4" long bolts to fasten the table top.
What do you think, or what do you recommend?
Larry B
Larry B
