After market glue bottles.
20K views 78 replies 31 participants last post by  johneone
I see a lot of guys using glue bottles on videos but that could be to hide the manufacture's name. Is there a good reason for me to use an after market glue bottle?
Only if you buy in large quantities. If you buy glue by the gallon it is easier to fill a more manageable container. Like Dan I have used recycled containers, Glue-bots, Dixie cups, etc.
Reactions: Blinky
#45 ·
I have these around for medical purposes, but that would be good. I did buy a couple of dozen small syringes of the same type for when I want to inject glue. They have a much finer tip for injecting glue into tight spaces. I guess you could wash them out and reuse these, but my 60cc syringes only cost about 60 cents each so why bother. They do come with caps to seal them between uses, if you can find the darn caps on a crowded workbench.
I have resisted the urge to buy large quantities so I'll always have fresh glue. I noticed that it thickens somewhat with age. I've found the baby bot by Fastcap to be handy for application to vertical surfaces. Otherwise, the Titebond squeeze bottle has worked great for me.
#46 ·
Several years ago I bought a 5 gallon bucket of glue which requires a small amount of catalyst to make it set up. I think the big bucket has been through a few freeze/thaw cycles and yet it still works fine. Looks just like any other white glue.
DaninVan is the man w/ the plan...
for volume gluing...
notched squeegee (notch the edge by scraping the edge over very coarse sandpaper)..
and this... (note the nozzle)
and the old standby... (in different sizes and stiffnesses)...
Forgive me for not answering your question. I would be leery of any aftermarket glue that doesn't have good reviews, or any reviews at all for that matter. It's good to be able to come to this forum for advice. There is tons of it.
My opinion on the matter is how much does your project mean to you or to others. A little savings now could result in major disappointment and catastrophe later. For me, I stick with TiteBond.
#24 ·
I have both sizes of Glue Bots. Far easier to use than the bottles. Better control of where the glue goes and the double chamber means that when you release the pressure on the sides, the bottle sucks the glue back into the bottle. You can cut the tip a little with scissors to control how much glue passes through. Far more control than using the glue bottle, and the tip on the Blue Bots has never clogged whereas the original bottle often requires a paper towel wipe to keep it from clogging.
I use brushes for dados, but I often have very thin strips of cutoffs, which I cut into short lengths and use to spread glue over any larger surface. Faster than a brush when you have short open time and a lot of pieces to connect. Thanks stick for the brush washing tip, I have always just tossed them out.
#29 ·
#31 ·
I use a roller for big glue ups where you need to cover area quickly. Biscuit & Roller Glue Applicator Set - Lee Valley Tools Index finger gets used quite a bit but I try and avoid that when I'm using Melamine or polyurethane glue as they don't come off, you wear them off. For really tight spots I use a syringe and large gauge needle. I have gotten some funny looks when I go into a drugstore and ask for the largest bore needle they have.
#32 ·
I used to buy strictly by the gallon, glue does thicken up if it sits for too long or it has an air void. If the bottle is seeing regular use you can roll the bottle around every month or so to keep it mixed. For long term squeeze the bottle to remove the air then recap it. Also as I began using dish detergent bottles, empty the gallon bottles into them, keep them full and secured.
For large wide open areas I use mastic trowels, you can spread with notched and smooth edges then hit it with hot water from the sink sprayer quick and easy clean up. Putty knives and different width drywall knives to suite.
