I recently purchased a Bosch RA1181 router table which has an aluminum top. It's a little rough and grabbing the wood. Has anyone had any luck sanding something like this before? If so, what grit? Wet or dry? Power or hand? etc.
Or is paste wax sufficient here?
I have read that it is best applied with a heat gun and then power buffed for optimal hardness. Agree?
Is it usually necessary to do multiple coats for a first-time application?
Thank you!
Thank you!
