Covid
Yes, I succumbed to the virus everyone loves to hate. Fortunately, I have been vaccinated & boosted but that didn't make me immune. Coughing, running nose & general lethargy were the primary symptoms. I didn't really feel like going into the workshop - just wanted to sleep. Finally came around today and thought we might catch up.
Main electrical Panel
Finally got all of the wiring finished and mounted the electrical cabinet to the base. Still have to make up cables for the Home & Limit Switch wiring.
VFD Panel
Got the VFD panel hooked up permanently to 220 VAC. Also, all the wiring from the controller is now connected to the VFD panel as well as the spindle power connections.
Cable Tracks
I procured a couple of cable tracks that I am pondering how to attach and mount. The one on the left will be mounted on the X-axis and is 10x20 mm. The one on the right is the main cable track and will be mounted parallel to the Y-axis. it is 15 x 30 mm. How to attach the ends of these cable tracks poses some interesting challenges.
Spindle Cooling
The following photos show the spindle cooling system I have chosen. It consists of two separate components. The first is the coolant reservoir and pump combo. It operates off of 12 VDC. The second is the fan and heat exchanger (radiator) which also operates off of 12 VDC. There are two challenges associated with utilizing this system. The first is how to physically mount these components on to the gantry. The second challenge is to figure out how to plumb these components since the tubing diameters for the heat exchanger and the pump are different and the tubing for the spindle is totally different. Stay tuned for future posts how I figure this out.
Z-Axis Rebuild
Still waiting for the parts to arrive from China. Stay tuned.
VFD Panel
Cable Tracks
Spindle Cooling
Z-Axis Rebuild
