Another look at Ray's tablet stand
4.9K views 16 replies 16 participants last post by  hawkeye10
@Raystafarian
Ray's post about making an easel stand for a tablet got me thinking about how to make something that was simple, strong, and required no hinges or hardware.
A lot of good suggestions followed his post with most agreeing that at least two legs are needed for stability. My experience with my iPad shows that the stand doesn't need to rotate between portrait and landscape. The tablet can be rotated in the stand and work very well. I have also found that a 30º tilt is a good angle for viewing and using the tablet.
So here's my concept: legs extend from the sides of the easel to form a strong equilateral triangle when opened. Stops at the top of the sides prevent the legs from opening more than 60º. The legs have a cross brace that adds to stability.
I don't need an easel stand so I haven't built this. However, I did make a proof-of-concept test of the leg assembly to make sure that it worked and stopped correctly at 60º. If you build one, make sure to post pictures.
The tablet images were exported as 2D images from Sketchup and the text added later.
Great design, Oliver. I can see where this could be adapted for use on larger items, too. Like a floor size easel for artwork, display rack, etc. One could use a single leg coming out of the center of the leg brace, making the easel a tripod, for use on uneven surfaces.
Nice logo on the drawings!
#13 ·
Oliver,
Did you forget that Ray wanted to be able to use the tablet bot vertically and horizontally?
