Here's the reply I posted at CNC Zone.
You'll find that most spindles are either 300Hz or 400Hz, with 300Hz being 18,000 rpm spindles, and 400Hz being 24,000 rpm spindles. These spindles are 3 phase motors, with the 3 phase voltage at high frequencies generated by the VFD.
Sticking with 2.2Kw chinese spindles, you can break them down into round, or square bodied.
Starting with the round bodied, there are two varieties, water cooled or air cooled. Both are about $200 for the spindle only.
All of these cheap spindles have limited power at lower rpm. So most should not be run below 6000-8000 rpm. The air cooled spindles have small, ineffiecient fans, so they can get hotter at low speeds than water cooled, and can not be run at low speeds as long as a water cooled. But it depends on the loads it's seeing.
My preference is the air cooled, which eliminates the hassles of water cooling.
At $200 (or less), these should be considered disposable. They won't last forever, but many people get 5 or more years out of them. And while most claim to have a 1 year warranty, don't count on it.
Because these are so cheap, quality control can be all over the map.
While I've never seen one in person, the square Chinese spindles are basically round spindles in a square extrusion. These are all air cooled, and have a larger fan than the round air cooled spindles. The larger fan makes them louder, but they'll also run cooler. These tend to cost a bit more, usually in the $300-$400 range.
The only "expensive" Chinese spindles I'm aware of are from UGRA CNC.
These spindles have much better quality control, are individually tested, and have a warranty and support you can count on. For some, that's worth the additional cost. For others, it's not.
I believe the spindle that AVID CNC sells is the same as the spindles from UGRA CNC.
