1 - 5 of 5 Posts
Discussion Starter #1
I have been working with hardwoods to make lazy susans using the 'wood mosaic' type of glued on surface. It has worked great using jigs on my bandsaw. I was interested in making t-tracks in sacrifice fences using a t slot router bit that works on common hex-head bolts but don't know the difficulties I will have. Thanks for any advice.
Richard
Welcome to the forum, Richard.
You should not have problem with T-slot router bit, but some of the bits require a groove cut first with a straight bit.
Richard, double sided tape will usually be enough to attach your wood to a fence or guide block.
1 - 5 of 5 Posts
