HI Michael
Like you I use the key hole bit most of the time for T-Slots and I use Toggle Bolts (5/16 x 4" long the norm.) and cut them to size when I need a short one like a 1 1/2" and because they are full thread they work great and all I do is grind the head on two sides to make a T-Slot bolts.. it's quick and easy to make a T-Slot bolt and it's about 1/10 the price of the standard T-Bolts from like Rockler,Plus one size on hand I can just cut off the threads and grind it quick and easy.
I did get a little feed up with the hack saw so I got a little chop saw from Grizzly and put my HF grinder into to chop off the toggle bolts and other items like threaded rod and alike and I don't always use the side grinder anyway so I put it to work this way.
Here's one more link from Bj for a Grizzly item, but it's at a great price and it works great for small stuff, I have a BIG 14" chop but it's a bit over kill on small fastners.
18.oo dollar chop saw..
http://www.grizzly.com/products/G8183
Just a note***when I use the key hole bit I always run it down the stock and then set it just a bit deeper and make one more pass,I like the one that's yellow, I don't recall the name right now but I get them from HomeDepot they work the best.
Bj
Bj
