Hi Mike
I just took a look at page 19, man that's some kind of jig, that looks like it would do the job but not a easy one to make.
The Duplicator I use is the one below,it will do it all,cravings, 3D,flat copy,etc.
They can be found on eBay for 40.oo to 80.oo bucks most come with a small 1/4 HP Craftsman router but I removed it and now use a roto zip motor with a V.S. control so I don't burn the bits up.
Bj
AxlMyk said:
For those with the Router Magic book, on page 19 is described a Router Duplicator..
A trimmer router sits in the bottom arm, and a guide pin is in the top arm.. The whole thing floats on a cushion of air so you can move it around.. You can use it in much the same way that the CNC router is used, only manually..
Seems like it would be a whole lot easier to duplicate things that way..
CARVING LINER ROUTER BIT
http://woodworkersworld.net/carving_liner_router_bit_bits.shtml
CARVING Ball Nose ROUTER BIT
http://www.precisebits.com/products...xtsearchParamVen=ALL&txtFromSearch=fromSearch
CRAFTSMAN ROUTER RECREATOR CARVER CARVING PANTOGRAPH ▼
http://cgi.ebay.com/CRAFTSMAN-ROUTE...ryZ20781QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
JUST A NOTE**** This one has RUST on the main shaft and MUST be removed, it must be clean and smooth ,(it may need to be replace) it's the main key to this machine, all the parts must side free on the main (3/4" ) rod, one other small note ,,,the seller is a bit high on the shipping charge,besure to check that out b/4 you bid.
(this unit should ship for about 20 bucks UPS ,7 to 10 days)
One more small note....4 brackets (Wheel Locks) are missing (in the pictures) on the side on the main unit,it's not to big of deal, you can make your own, I will try and find them in the manual and I post a snapshot of them.
The pictures below are from the MANUAL and it can be downloaded from the Net with luck the seller may have one.
If you buy this one and you don't get the manaul with it and you can't find it on the NET let me know and I will send it to you (it's a 17.5mb PDF file) 42 pages.
